Old 01-07-2016, 02:26 PM
carp carp is offline
Default John Deere swing machine 2954d
A few years back I made an excavator it was a first attempt but not very good, so I decided to have another go, I have completely remade the under carriage but for now have reused the old boom arm and bucket, hopefully in the future it will be replaced but seems ok at the moment.
Tracks are made from k1 attachment chain and tracks made from aluminium angle, my girlfriends dad then took them all to work and got them anodized. Motors are mfa como 970d planetarys 105:1, they are attached to angle grinder heads which have a 3:1 reduction, I may upgrade the Motors to brushless at some point to improve the travel speed slightly.
I used a China cat slew bearing it work a ok but I don't think it will hold so I'm going to change it to a taper bearing set up and possibly 2 slew Motors.
Old 01-07-2016, 03:34 PM
Default Re: John Deere swing machine 2954d
Cool. Looks like a forestry machine. 1/10 scale isn't it?
Old 01-07-2016, 04:26 PM
That looks awesome! Add some auxiliary hydraulics and you can put a grapple on it.
Old 01-07-2016, 07:18 PM
looks great. I like the fact that you used parts from a grinder to make it. And is that sheet metal? it doesn't look aluminum.
Old 01-08-2016, 03:31 AM
It's 1/8th scale, all the cab is made of sheet metal but I might 3d print one soon here's a couple of videos
http://youtu.be/AXz2SekeKk0
http://youtu.be/hpLV-qBpCm8
Old 01-08-2016, 09:21 AM
2nd vid is marked private
Old 01-10-2016, 01:05 PM
CustomCrawlerz's Avatar
CustomCrawlerz CustomCrawlerz is offline
CustomCrawlerz is on a distinguished road
Thumbs up Re: John Deere swing machine 2954d
Was that the "Lady" upper frame? Seems to have decent enough power with the setup you are using. Looking good.
