Old 01-22-2016, 05:18 PM
stephenk99 stephenk99 is offline
stephenk99 is on a distinguished road
Default mfu ?
Hi
I am new to the truck world and trying to find out the differences between the tamiya mfu as there are at least 3 different versions.
I have a scania r620 and want to know the best one suited for this and if the esc is built in unit and if you use this or have an external speed controller any help would be apprehiated as a little confused
Steve
Old 01-22-2016, 05:45 PM
Default Re: mfu ?
hello maybe I can help. Tamiya make a euro version for that truck that has the authentic Scania or euro truck sound. I personally use the built in speed control only for easy hook up and space management. Some people use a external speed control when they require more power (amps or voltage) than what the unit can push. I use my trucks to haul heavy loads (dirt, rocks and trailer. If you need more power than that then you would go external. There are other much cheaper sound units on the market, just no lights. That's another kit all entirely. In the cheaper kit you can program in a few different engine sound and brake sounds and horn also. So in all what's best is usually what's best for your pocket. Tamiya's unit is basically convenience in box instead of a unit for every action you wish to do with your truck. And all can be controlled from your radio.
Old 01-22-2016, 06:37 PM
Default Re: mfu ?
Thanks for reply really helpful
Old 01-22-2016, 07:39 PM
Default fill out your bio
You should fill out your bio. a lot of guys like to know who there talking to. And you just might have one of us in you local area.
