Old 03-26-2016, 03:04 AM
Steamindan Steamindan is offline
Steamindan is on a distinguished road
Default Dx8i Carson tipper control
Hi I have a tamiya man tgx and a Carson frigel tipper. How can I operate the tipper body via tx without wiring to rx in tractor unit. Is it possible to bind two rx or do I need to create a different model within the menu. I want to be able to hitch and unhitch trailer without touching the model. Many thanks
Old 03-26-2016, 02:42 PM
jack van's Avatar
jack van jack van is offline
Default Re: Dx8i Carson tipper control
try to bind 2 receivers at the same time maybe ?
Old 03-26-2016, 06:55 PM
What radio do you have????
Old 03-26-2016, 10:00 PM
Yes you can bind two receivers at the same time for the same model copy. But the channels will be the same on both receivers, meaning if you're using throttle, rudder, aileron, eleveron for the truck, you can't use the same channels for the trailer too.
Old 03-26-2016, 10:02 PM
The title being Dx8i I would assume is Spektrum.
Old 03-27-2016, 03:48 PM
Sorry for the delay, the radio I a DX8 spektrum. Thanks for the help.
Old 03-27-2016, 07:01 PM
Prop Shaft's Avatar
Im still not quite sure what your asking. How many channels are you needing? You can bind 2 receivers to different models on the transmitter and change back and forth.
If your asking how to program the transmitter to make the usable channels do what you want and assign to what switches you want? Then I may be able to help. I just went through this process to get my dx9 to do what I wanted it to. Its probably going to be a similar process for the dx8.
First step is to update the transmitter with the latest firmware. I had to do this in order to access the multi rotor model type. If you already have this type on your transmitter then you shouldnt need to update the firmware. Simply selecting multi rotor model type will allow you to assign any channel to any stick/knob/switch, or whatever. Hope this is a help.
Old 03-27-2016, 07:09 PM
Prop Shaft's Avatar
Ok I re-read first post. I think I know what your asking now, sorry Im tired.
Binding a second reciever would be a way. Something like this could be another possiblity.
http://www.rccrawler.com/forum/vendo...d-channel.html
Old 03-28-2016, 02:12 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
I would say binding another reciever to a different model memory on the radio would be the easiest way to operate the trailer as I was thinking something similar if I put a wrecker body on my day cab as I have a dx6i and 5 channels are already gone and I would need a few more to operate the wrecker body, and switching between the models is just a matter of pressing a few buttons .............
Cheers Tracy
Love my Kenworths
