Old 04-12-2016, 07:43 PM
Machfab Machfab is offline
Machfab is on a distinguished road
Default Slewing bearing
What are you scratch-build guys using for a slewing ring bearing on a 1/14 excavator? Any sources?
Old 04-12-2016, 08:41 PM
Default Re: Slewing bearing
all from rcbrmin there the slew ring, gear and pinion gear for the kat
http://www.rcbrmin.com/index.php?mai...roducts_id=769
http://www.rcbrmin.com/index.php?mai...roducts_id=662
http://www.rcbrmin.com/index.php?mai...roducts_id=779
Old 04-14-2016, 12:20 AM
I just purchased one. Its great. I was pretty dissapointed when i found out their is no bearrings in it but it is still a good buy. Ended up chucking it up in the lathe cause it was about a half inch to tall.
Old 04-17-2016, 11:57 PM
Busydad Busydad is offline
Busydad is on a distinguished road
Torrington make some nice thrust bearings . Not certain if they would fit your application ..
Old 04-18-2016, 08:55 AM
I think I will try a couple of thin section bearings and see how they perform.
Old 04-21-2016, 01:28 PM
ptebbe ptebbe is offline
I used a tapered bearing on the top (carries both radial and thrust load):
http://www.mcmaster.com/#standard-ba...rings/=122wlwm
And I used a regular ball bearing underneath. I machined aluminum bearing holders and screwed a 72t gear-ring onto the top one.
This might have been overkill, but it is super tight and it turns very smooth.
Paul
Old 04-21-2016, 04:37 PM
ptebbe: Where did you get that 72t gear ring? Do you have a link? Thanks in advance! :-)
I also used a tapered bearing on my excavator, but I also had another opposite-facing tapered bearing for the bottom one so that the tapers combined where in a X shape. It got very sturdy, tight and rolls very well (details here)
Best regards,
Stein :-)
