Old 04-19-2016, 09:32 PM
Prop Shaft's Avatar
Default Disco Bruiser
Not sure if many over here will care about this build of mine. But I wanted to share it non the less. The original build can be found here incase anybody cares.
http://www.scale4x4rc.org/forums/sho...ighlight=Disco
This was my first attempt at a scale build of any kind.
Bit of an update. Made some simple door latches.
Then got the driver secured with the help of a seat belt and a screw into his back....
Used a spring to mount the seat belt inside the seat to allow for some give.
Some random shots.
This one is pretty much done now. Still contemplating an exhaust, but other then that I want to get it out for some action pics/video.
Old 04-20-2016, 04:46 PM
Prop Shaft's Avatar
Default Re: Disco Bruiser
Added some details.
Dexters "tool" kit.
Picked up some Land rover metal decals for the G2 way back when. Always planned to use one for this build and finally got around to applying it. The issue is they are printed in a flat line, and don't translate well to curved areas such as hoods or windshields. So I used a technique I first figured out while applying a Subaru windshield decal on my sti. Maybe showing this method will help someone out. Heres how I did it. First I stuck a piece of masking tape over the area where the decal was to go.
Then mark out the borders by cutting the bottom flush with the hood, and marking the rest with a sharpie. Then peel off the masking tape and tape it down to the bench sticky side up.
This is the decal that needs to be curved.
The next step is to cut the decal into its individual letters. Just cut them right in the middle of the spacing between the letters. You also need to put the spacing between the letters as well. Then carefully stick them face side down, being careful to center them from top to bottom and keeping them touching left to right.
Then trim the edges flush with the lettering. This allows for more accurate centering of the decal when placed.
Peel the backing off the letters.
Now stick the tape down on the hood being careful to center it and keep the bottom edge flush with the bottom of the hood.
Peel off the masking tape and your done. The letters I had to paint over on this are back in all their glory.
Old 04-21-2016, 01:44 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Cool build and that link to the other website kind of makes me loose the whole morning.
Will have to go back for a more in detail look at some of the neat improvements and fabrications!
Old 05-07-2016, 10:13 PM
markturbo markturbo is offline
markturbo is on a distinguished road
Great detail work
Old 05-29-2016, 02:09 PM
bigrigbri bigrigbri is offline
bigrigbri is on a distinguished road
Great build sir you have a good eye hand coordination.
Old 05-29-2016, 10:40 PM
Lost_ Frequency's Avatar
Lost_ Frequency Lost_ Frequency is offline
Lost_ Frequency is on a distinguished road
Looks great! I really like the wheel and tire combo
Old 03-08-2018, 08:06 AM
ittigger ittigger is offline
ittigger is on a distinguished road
Great details.
Old 03-08-2018, 08:39 AM
kaptain Jack's Avatar
This is so cool!
