Old 04-20-2016, 06:18 AM
terryL terryL is offline
terryL is on a distinguished road
Default Binding two RX to one Tx
Hi.
I having problem binding my two RX to my Tx? I had them working once but now can only get on RX to bind? I have a flysky i6 which works great. Any help as to procedure on the binding would be appreciated .
Terry
Old 04-20-2016, 10:23 AM
Default Re: Binding two RX to one Tx
On some receivers the signal is actually swamped out if the transmitter is too close to the receiver. So, while you are binding cover the antenna on the transmitter with your hand and that will help it bind more easily.
This even helps spektrum radios bind more easily.
Old 04-20-2016, 09:37 PM
Thanks will give it a try.
