Old 05-12-2016, 05:13 PM
JamesBC JamesBC is offline
JamesBC is on a distinguished road
Default Question about rear frame member
Can someone tell me if this frame member will fit the Globe Liner and Grand Hauler frames.
I have never seen the Scania or Man so not sure if the frames are the same. Want one like it for a Grand Hauler build I have been collecting things for.
Thanks for your time.
Jim
Abbotsford, BC
Old 05-13-2016, 05:35 AM
Berman's Avatar
Berman Berman is offline
Default Re: Question about rear frame member
Frame rails are the same between all trucks apart from hole provisions for different ancilleries and the lengths.
Globe/King has the same mounting holes in the chassis rails for its rear crossmember bracket, so it should mount straight up, only thing is you would lose the factory rear bumper.
4 tractors/trailers and still no king hauler...
Old 05-13-2016, 09:12 AM
Thank you Berman, that is exactly what I needed to know. Starting with blank frame rails and somewhere down the line will build my own rear bumper for it.
thanks again
Old 05-13-2016, 12:23 PM
Berman's Avatar
Oh ok if you are using some aftermarket blank frame rails then they might not have the exact same bends in the c channel and could require some light filing of the alloy part you posted above as it sits inside the rail at the back. Also obviously you would have to drill the two mounting holes either side for your screws (amongst all your others).
Old 05-13-2016, 01:19 PM
Yep, lots of drilling and taping to be done. The frame rails are from Ric at PMD, love those as they are a perfect match to Tamiya rails, hence no filing off corners of items to make them fit.
