Old 06-29-2016, 10:54 PM
thebat's Avatar
thebat thebat is offline
Default upgraded front shocks
hey guys im looking for stiffer heavier duty shocks for the front shocks. on a new truck im gonan be building soon. thanks alot.
Zach The Bat Flowe
Keep On Rollin.
Old 06-30-2016, 09:36 PM
Default Re: upgraded front shocks
Go to the automotive store & get some same diameter coiled compression springs that are stiffer to put inside shock.
Old 07-01-2016, 03:19 AM
Backlash Backlash is offline
If you want to go super heavy duty, then remove the spring from the stock shock, and replace it with a length of silicone fuel tube..
Old 07-01-2016, 05:50 AM
Northern Farmer's Avatar
Push style pens also have stiffer springs inside of them.
Old 07-01-2016, 06:44 AM
Doggy's Avatar
Doggy Doggy is offline
Why nobody use real shocks with oil, and let the springs take the load you want? I am just looking into materials to use for leaf springs to have flex and adjust the thickness of the leaf to decide how much load you want to carry. Easier way is if you use airbag dummy springs.
I will make some examples when I come to that on my custom truck build, as I want to replicat exact 1:1 system.
Old 07-01-2016, 08:38 AM
If your using stock Tamiya suspension you can go to Tamiya USA and order spring leaves to add to your springs they have 4 different lengths. It works a lot better than trying carry the weight on shocks. Use the following link and look at the first 5 items on the parts list.
http://www.tamiyausa.com/product/rcp...2#.V3Zf4pD3aK0
This is the best picture I have albeit a rear set I did the same with the front. If you are hauling the weight this will take care of the squat and will still allow the suspension to flex. I believe I added 4 leaves per spring assembly.
Old 07-01-2016, 11:40 AM
Thumbs up Re: upgraded front shocks
That's a great idea! Have some spare leaf springs going to give this a shot.
Old 07-01-2016, 09:48 PM
thebat's Avatar
thanks for all the good ideas an suggetrtions on this guys i will give them a try
Zach The Bat Flowe
Keep On Rollin.
Old 07-02-2016, 02:37 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
On my bruder mack cab on tamiya chassis on the rear shocks I just removed the springs and cut some aluminium round rod and placed it in the shock bodies to stiffen it up so there is no sag and did away with the front shocks as its getting used as a race truck,,,,,,,,,,,
But on my other truck I used the springs from pens as well in the front and rear and it works well without the need to add extra leaf spring................
Cheers Tracy
Love my Kenworths
Old 07-03-2016, 02:09 AM
Here's my take on stiffened leaf springs. Had to grind off the rivets holding the stacks together. 2 blades were added to each stack, total of 5 blades in each leaf spring. Should help with raising the front end a bit.
