Old 06-30-2016, 02:49 PM
cosworth34677's Avatar
Default magom hrc pump question and input?
anyone use his pump from magom hrc?
http://www.magomhrc.com/en/hydraulic...ated-tank.html
i've used there mini pumps for a while the fisrt run where ok and the secound verison was really good still run mine, but the bad part was the little 480 brushed motor they used, i would eat those little guys up! but this is suposed to be bushless and has a prv built in. i'm hoping they are ok becuse i orderd it and one of these .
http://www.magomhrc.com/en/hydraulic...ith-motor.html
the question is are these ok to run all the time or do i still have to mix them with the servo on the valves? and dose runn all the time help with wear and tear?
Old 06-30-2016, 08:05 PM
trucker n's Avatar
Default Re: magom hrc pump question and input?
I have the same pump but mix it with radio so not running all the time
Old 06-30-2016, 10:49 PM
It might be a small enough outrunner that it could be ok start/stop continually, but if you ever have esc freeze happen, then it'd be recommended to have it run continuously of at least 20% all the time & with valve ch mixing the motor ramp up to necessary speed.
