Old 07-01-2016, 02:12 PM
crusher's Avatar
crusher crusher is offline
Default Hydraulics
Hi, I am scratch building a Cat 330b, 1/14 or close. I am going to take a shot at doing my own hydraulics, starting with the cyls. my questions are what type of material to use (brass s/s etc.) and what wall thickness should I be looking at?
Thanks for any suggestions you can offer.
Terry
Old 07-01-2016, 03:20 PM
rc_farmer's Avatar
Master Builder
Default Re: Hydraulics
Honestly, if you don't know what material, sizes, etc already, you will be better of buying cylinders already made. You're gonna need nipples, o-rings/seals, brass, stainless steel, aluminum, etc.....and a machine to make all the parts....just trying to save you a little headache and a lot of money...just my .02 worth
Giving up is not an option!!!
Old 07-01-2016, 09:46 PM
Rimrock Rimrock is offline
1.5mm +/- 0.5mm wall thickness is natural. Will also like to mention that we are, among else, talking about machining external and internal o-ring grooves of +/- 0.05mm tolerances to make it a success. And to have detailed knowledge of how full scale cylinders looks like inside doesn't hurt.
Old 07-02-2016, 01:08 AM
jack van's Avatar
jack van jack van is offline
hmm there is an option that you can use use to learn buy a part to learn from so you have a hands on part or learning tool just like a school does and most of the other builders do how else does someone learn but by example :
Old 07-02-2016, 04:07 PM
crusher's Avatar
Thanks for your replies, I do have a mill, lathe etc. and some experience using same. I was only looking for material, sizes etc.
Nothing ventured nothing gained.
Terry
Old 07-03-2016, 04:13 PM
Go to magomhrc.com and there you can get the dimensions of what they use. I have a Track loader from them. They sell cylinder parts. So you can build your own.
Old 07-03-2016, 07:15 PM
crusher's Avatar
Thanks for that mci.
Old 07-06-2016, 10:20 AM
Ideally, you will want to use brass.
Old 10-29-2016, 04:16 PM
oldguy70 oldguy70 is offline
oldguy70 is on a distinguished road
Crusher
I use all aluminum for my cylinders the tube is usually .064 wall and the ends are welded in with a welding rod that uses propane or map gas torches. Many laugh at me but the cylinders take 300PSI as this welding rod when used properly makes the weld stronger than the original aluminum. I usually clean up the inside of the tube with 600 grit sandpaper and scotchbrite the seals are neoprene u cups.
If anyone is interested the welding rod comes from Weeks Distributors in the states. All my models are welded together with these rods saves the expense of a welder and power to run it.
Earl
Old 10-30-2016, 08:32 AM
Alex39 Alex39 is offline
Alex39 is on a distinguished road
You can buy cylinders here https://www.facebook.com/profile.php?id=100011907454158
I have the same, it work exellent
