Old 07-14-2016, 12:38 PM
Pawloosw Pawloosw is offline
Pawloosw is on a distinguished road
Default Fuchs 712SS Scrap Loader [1:14]
Hello guys,
I'd like to share with You with some pictures of my last project. It is an 1:14 scale oldtimer Fuchs 712SS scrap loader.
This is how it looks (here are a different supports mechanism, the rest are the same).
I've always make many pictures of model i made and it's quite difficult to add hundred of pictures to forum so i made videos and upload them to Youtube. Here You can see how i made every detail of this model.
Part 1:
https://www.youtube.com/watch?v=zPQzhJZpE9U
Part 2:
https://www.youtube.com/watch?v=GAQMOjfLY3Q
Part 3 (test actually):
https://www.youtube.com/watch?v=jjnZwEJeT3g
As You can see on the video's, the chassis are complete.
Soon i will add some update.
Greetings
Old 07-15-2016, 05:34 PM
tessen's Avatar
tessen tessen is offline
tessen is on a distinguished road
Default Re: Fuchs 712SS Scrap Loader [1:14]
wow! impressive! I liked very much, congratulations,nice model and very detailed the rc, it can see have a lot of hour of work
regards
Old 07-15-2016, 05:37 PM
Awesome craftsmanship!
Old 07-15-2016, 07:28 PM
Thumbs up Re: Fuchs 712SS Scrap Loader [1:14]
Excellent build, great technique on everything especially making the small details!
Old 07-15-2016, 08:31 PM
FabOne's Avatar
FabOne FabOne is offline
SUPER job!
Keep posting.
-Terry
FabOne
NW Ohio
Old 07-17-2016, 09:00 AM
Thanks for reply Guys. It's really nice to hear words like that.
In few days i will get laser cutted parts to make arms. They are 100% made of steel.
Below a few pictures of things i made last time.
Primary arm weight is 450g (with ballbearings etc.)
File Type: jpg IMG_8814.jpg (157 Bytes, 250 views)
File Type: jpg IMG_0175.jpg (157 Bytes, 248 views)
File Type: jpg IMG_0177.jpg (157 Bytes, 250 views)
File Type: jpg IMG_0178.jpg (157 Bytes, 251 views)
File Type: jpg IMG_0179.jpg (157 Bytes, 251 views)
Old 08-05-2016, 05:13 PM
tessen's Avatar
Hi Pawloosw
I like your assembly system for the arm, i´ll do some similar, and the octopus (i don´t know if is the correct term) is impressive, the arms of the octopus are made with foundry?
Only one sugestion / constructive criticism, in my opinion,i don´t like the use of ballbearing in the arm, i think is better to use brass/bronze bushing. In the ballbearing the hidraulic ramp could apply a great force, I consider that it is not best solution
regards
Old 08-20-2016, 01:41 AM
Hi Tessen,
Thanks for the reply. The arm is made of steel sheet 1mm thick.
About the ballbearing - it works really smoth. I don't know what do You mean by saying " the hidraulic ramp could apply a great force " ?
Old 08-20-2016, 01:12 PM
Jared Jared is offline
The build is looking good! Always interesting for me to see older European equipment.
I think Tessen is saying the balls in the ball bearings could crush a little and not turn smooth anymore if too much side force it put on them. Also if they don't rotate very far each ball will wear a little groove of it's own into the races which is probably why you always see bushings used on heavy equipment. But that isn't to say that ball bearings won't work for you with the relatively light loads and low hours most models see.
Old 08-22-2016, 02:32 AM
Are You sure, the bearing is not strong enought? ;-)
Old 08-22-2016, 09:35 PM
Oh yeah, the swing bearing will be fine. We were talking about the small ball bearings in the boom for the cylinder ram ends to pivot on. At least from here they look like ball bearings.
Did you buy the swing bearing or build it?
