Old 07-23-2016, 09:33 PM
Trucker47's Avatar
Default CAT 966K XE
Hey everyone,
Well after a long hiatus from the RC world due to working and completing post secondary I am finally at a place where I can get back into it. Some of you may know of my build from about 4 years ago that can be found here:
http://www.rctruckandconstruction.co...ead.php?t=3260
Decided to use some of the parts from that build in the new one but also I have re-designed almost all of it by the time its done haha. Anyways I am planning to build a 1:14 CAT 996K XE wheel loader. I picked up a 1:50 model and began modelling everything in Solidworks to get the basic geometry down and then Ill be designing all the hydraulics and electronics for the system.
Ill try to keep the thread updated as often as possible with CAD design work and the metal work once I can get a lathe and metal mill
Also here's a picture of my electronics lab where Ill be trying to design all the systems for the loader By trade I am a Robotics and Mechatronics Technologist
If you have any questions Ill try to help answer them
Thanks!!
Old 07-24-2016, 05:14 AM
Doggy's Avatar
Doggy Doggy is offline
Default Re: CAT 996K XE
Great start. When I look at all the loader threads, everyone is doing CAD all over again. Maybe the best thing would be to make open source version, so we dont spend time on the same design, but spend it to upgrade already made design.
How will you make the rear panels? Mill it from a single block, or use sheet metal? I am searching for the best solution to make 3D surfaces. Right now I am using 3D printer, but I am thinking a lot about milling molds and try to do a real injection molding, or maybe press sheet metal over milled mold.
Old 07-25-2016, 11:57 PM
Well looks who back at 'er... good to see you again Chris... your title is 996, but the one pictured is 966... which is it?
Old 08-12-2016, 01:05 AM
Trucker47's Avatar
Hey Doggy, thanks! Haha that would be nice, the amount of hours I spend on CAD doing simple things, it would be nice to skip it! Currently I am planning to build the chassis from 1/8th sheet steel and weld it all together. Then for the complex surfaces I may have them 3d printed or build them out of sheet steel. Plastic is nice for the ease of use but I want the loader to be heavy so it is more realistic.
Hahaha yea I am finally back which is nice. You caught me, messed the title. I am planning on building a 966K XE loader. How can I edit the title?
Little update here, work has been very busy the last couple weeks so not much progress. I have got some preliminary CAD models done of the outside shape and begun the design of the electrical system. Here a screen capture of the CAD:
-Chris
Old 08-15-2016, 02:18 AM
Trucker47's Avatar
Another update on the CAD work, slowly getting there. Pretty sure i've got the axles sorted and begun work on the bucket linkage.
-Chris
Old 08-15-2016, 06:56 AM
Default Re: CAT 966K XE
welcome back Chris . all fixed
Old 09-05-2016, 11:03 PM
Trucker47's Avatar
Thanks ihbuilder.
Just picked up a refurbished Robo 3D +Plus 3d printer to do some of the plastic work and prototyping as can't afford the metal working tools yet and gotta say it was well worth the money. Did some test prints of the wheel hub, and rear bumper to test it out and the results where pretty dam good. And they have been pretty accurate.
-Chris
Old 09-06-2016, 07:13 AM
Looks like a pretty good resolution .
Old 09-06-2016, 07:18 AM
Rimrock Rimrock is offline
Looks like a great start) that's the most durable solution, putting a gear motor directly on each wheel, much less trouble than having a standard axle and transmission I would say.
Old 09-09-2016, 12:36 PM
Cat966c Cat966c is offline
Fhahfhurhdhdhdhshxheshxhdbshxjd dhhebdvdbdhd
Old 09-09-2016, 02:10 PM
This looks like what my cat types when I'm not looking.
Old 09-09-2016, 11:14 PM
His cat 966 is typing now? But it's just a couple pieces. It'll be unstoppable once it's built...
Old 09-15-2016, 01:06 AM
Trucker47's Avatar
Thanks, yea I was very surprised how good the resolution was for a <$750 3D printer!
Few More update pictures, the printer pretty much runs non stop when I get home from work!
-Chris
Old 09-18-2016, 04:40 PM
Trucker47's Avatar
Some more images of the prints!
-Chris
Old 09-19-2016, 02:19 PM
Looks good man! Where did you get the printer???? Iydmma
Old 09-24-2016, 11:32 PM
Trucker47's Avatar
Thanks Cat 966c!
Old 01-11-2017, 11:27 PM
Trucker47's Avatar
Been slowly working away at the design and getting parts printed. The holidays slowed things down and I have been very busy with doing CAD at work.
Anyways I got the front axle completed and I have been working at the front chassis. Also been doing some very slow design of the controller system using a system of a 2x Xbee Pro's, an MSP432 mCU and a Arduino 2560 Mega.
Thanks,
Old 03-06-2017, 01:57 AM
Trucker47's Avatar
Still here, just more progress on the plan and CAD Models:
-Chris
Old 03-06-2017, 10:46 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Hey Chris. Good to see some parts getting completed. I like the idea of printing the loader. Bigpipespete is over in the LMD and has some nice machines you should check out. Keep us update as the build continues.
Greg
Old 03-08-2017, 12:50 AM
Trucker47's Avatar
Hey Greg,
Thanks! Glad to be making some progress, trying to enjoy the journey more than the completion I guess I must be getting older haha. Awesome I should see if I can meet up with him. Definitely will do!
Decided to try out the Cylinders and hydraulics from Magom HRC in Spain as they offer custom cylinder lengths in a variety of sizing. They had awesome customer service and I received my package in 6 days from Spain for only 16 euro!!
Being a CAD junkie first thing I did was draw it up to get it into the model.
Looks like it is going to be a great fit, now I need to finalise the remaining cylinder lengths and hydraulic system so I can order the rest and test them out! Check them out at http://www.magomhrc.com/en/
-Chris
