Old 07-25-2016, 02:15 PM
Default Question about RC4WD Wheels.
I'm using a Rigid Driven front axle and I bought some of these wheels;
I also bought some of these adapters for the axle;
The adapters replace the part to the right in this photo;
So when you bolt all these parts together how do you get to the actual lug nut on the axle?
If you are thinking I should put the adapter on the axle, tighten the lug nut, then add the hub cover and then the rim and bolt them all together with the 10 face bolts you can see if these wheels were on the axle there is no way you would get to the bolt heads on the backside of the wheel.
Old 07-25-2016, 02:18 PM
Default Re: Question about RC4WD Wheels.
Maybe I need these wheels, I can see how they go together.
Old 07-25-2016, 02:26 PM
I will have to work at it more when I have more time but I just don't think there is the kind of room to work from the back side of the rim once on the axle and truck.
Old 07-25-2016, 07:34 PM
Cossett's Avatar
Cossett Cossett is offline
On Leave
on the red inserts they are threaded of the tiny screw to go in then the rim over and then the nut ,
when I put my ones together I use loctite in the screws / insert let then dry then put the rims on just be careful with the screw you dont over tighten them.
Cheers Tracy
Love my Kenworths
Old 07-25-2016, 07:59 PM
My parts have no threaded holes.
Old 07-26-2016, 12:46 AM
Cossett's Avatar
On Leave
My backing hubs did, unless the shop I got them from did it.................
Cheers Tracy
Love my Kenworths
Old 07-26-2016, 05:41 AM
Cheers Tracy
I need to correct myself, the backing plate does have threads as you mentioned but I'm using the adapters for a driven axle, this means the original backing plate is discarded and the adapters are used which have no threads.
Old 08-01-2016, 08:22 PM
Well, I have my wheel dilemma figured out. Two set of wheels, one set of adapters and some parts of each used here. Good enough for who it's for.
Old 08-01-2016, 08:32 PM
Probably going to do something different with the lug nuts, not really feeling it this way.
Old 08-04-2016, 05:49 PM
Changed the lug nuts out for some stainless nylock nuts and added some acorns to the center.
Old 08-04-2016, 06:24 PM
those look sharp claus
Old 08-04-2016, 06:25 PM
Well, it's pretty bad when you can't make up your mind on something so simple but I went back to the RC4WD fake hubs and kept the nylock lug nuts. Just wish those center nuts didn't stick out so far.
Old 08-04-2016, 06:26 PM
Thanks mark, I'm never really happy.
Old 08-04-2016, 08:11 PM
FabOne's Avatar
FabOne FabOne is offline
Claus-
I think they look AWESOME!
-Terry
FabOne
NW Ohio
Old 08-05-2016, 01:53 AM
Originally Posted by FabOne View Post
Claus-
-Terry
Thanks Terry!
Old 10-08-2016, 02:04 AM
Berman's Avatar
Berman Berman is offline
Those acorn nuts would look better without the standard nuts underneath, but I like how you have used regular nylock nuts, goes with the wheel.
I like those wheels, I want the same ones for my reefer (as the tractor has alloys) as they make good looking singles, problem is I need 4x hex and 2x bearing adapters.
4 tractors/trailers and still no king hauler...
Old 10-08-2016, 07:19 AM
Th studs were too long not to use the standard nuts under the acorn nuts, in the end I put the standard nuts on first, behind the rim. That also moved my wheels out slightly. Which is something I wanted.
Old 10-08-2016, 01:43 PM
Berman's Avatar
That was going to be my next suggestion but on the other side of the adapter (if there is room) and you wanted the same offset. I had to do this with some of Steve's wheels to run acorns as the bolts I bought were slightly long.
Old 11-01-2016, 08:36 AM
markturbo markturbo is offline
markturbo is on a distinguished road
Thanks for posting this as I've been looking at these as well. Im currently using the Tamiya inner rear wheels as front drive wheels with a TLT front axle. But I'd like to go with a wide front wheel and tire. I wonder if they would work well on the TLT axle.
Old 11-01-2016, 12:29 PM
PM sent
