Old 08-02-2016, 10:15 AM
Default All wheel drive truck
Hi Guys,
I have converted a Tamiya king hauler to a ridged tipper, I'm looking to make it an all wheel drive truck, what's the best motor to put in it if I'm using a Tamiya front drive and steering axle?
Thank you
Old 08-02-2016, 01:51 PM
Default Re: All wheel drive truck
Do you have a GRU and what reduction does your T-case have? Are you going to use it in soft dirt or sand? You want to be able to have wheel speed if your in softer material so the questions above make a big difference. Outside of the speed if you don't use a GRU the stock can is fine and it's even better if you end up with a lot of reduction.
