Old 08-11-2016, 05:22 PM
wrighty2482 wrighty2482 is offline
wrighty2482 is on a distinguished road
Default 1/32 komatsu excavator
Hey lads and ladies I'm looking to build a 1/32 komatsu excavator just looking for help. I will start putting up picks once I start thanks everyone
Old 08-21-2016, 06:29 PM
Default Re: 1/32 komatsu excavator
Hey just want to get a bit of feed back on cold weld. I want to do the screw mechanisms but I'm using 3 mm brass tube and I don't have the tools to weld it will cold weld do. Or will I have to tig weld ?
Old 08-21-2016, 08:40 PM
You'll want to solder brass, with a very hot soldering iron or small propane torch.
Old 08-22-2016, 05:37 PM
Hey thanks for the videos I have seen them b4
When I use the torch do I need flux or does the solder have enough thanks for ur help already
Old 08-22-2016, 07:09 PM
I've always used a flux, it flows the solder, makes for a better joint.
Old 08-23-2016, 05:03 PM
hey i didnt get any flux yet put i did make a good solder/weld today so im one step closer
