Old 08-16-2010, 08:22 AM
Question MFU lights ???
After installing a pair of PMD square headlights on my latest project, I found out that I now need 2 LEDS per side for the headlights. Can I just add an LED per side in parallel to the normal headlight LED or some other way? Thought about using the fog light LEDs so I would have seperate control for low and hight beams. Any help would be appreciated. I am installing a MFU in this truck.
Thanks,
Lynn
Old 08-16-2010, 08:50 AM
Roadmasters's Avatar
Moderator
Default Re: MFU lights ???
As long as it is in parallel where it draws the same voltage as normal it would be fine.there is an extra plug in the mfu (number 14 I believe). You can use a tlu-01 light set but on the plug there is a ridge on one side that has to be removed for it to fit into the socket. I did it on my mfu and it was fine.
Arioch
Old 08-16-2010, 02:41 PM
Thanks, What controls the extra socket? Is it controlled with the running lights?
Old 08-16-2010, 03:13 PM
Moderator
F I remember rite yes, I think it comes on with the clearance lights
Arioch
Old 08-16-2010, 03:40 PM
derailed derailed is offline
derailed is on a distinguished road
how many lights you using?
just the 2 headlights per side?
i wired in an extra pair of leds parallel into one once
it turned out that one was brighter than the other
