Old 11-15-2016, 12:02 PM
rc_farmer's Avatar
Master Builder
Default Another Deere in the field
http://vid60.photobucket.com/albums/...psc2lq94hp.mp4
These two links are the same, photobucket has been acting up. In inspired by davaante to get off my duff and finish mine. Its not quite done yet, but its getting there.
Giving up is not an option!!!
Old 11-15-2016, 12:20 PM
Default Re: Another Deere in the field
Looks good Rob!
Old 11-16-2016, 05:24 AM
ddc333 ddc333 is offline
Do you have build pictures
Daniel
Old 11-17-2016, 03:32 PM
rc_farmer's Avatar
Master Builder
I will post up some soon.
Old 12-04-2016, 01:24 AM
davaante25 davaante25 is offline
davaante25 is on a distinguished road
Good Job!!!!!! Glad I can inspire
Old 12-04-2016, 03:22 AM
Awesome as always buddy
Old 12-09-2016, 06:09 AM
Rob did you use the 210:1 ratio for your steering actuators?
Old 12-09-2016, 09:38 AM
rc_farmer's Avatar
Master Builder
I used the 100:1, they are a lil faster and still have good torque. i also cut out more of the frame and removed the "stops" to give more radius
Old 12-11-2016, 12:50 AM
Thank you, are you planning to make your idle wheels movable?
Old 12-11-2016, 04:13 PM
rc_farmer's Avatar
Master Builder
No, a lot of work to cut them out, so i use bearing in the bottom of the road wheels, works well, because the road wheels are recess just enough that the bearings stick out slightly from the bottom.
Old 12-11-2016, 07:58 PM
I know exactly what you mean by a lot of work. It took two days but I managed it, and the end result was very satisfying lol. I'm working on leds now. Have you ever taken the top off of the cab before? Ive been trying to figure it out for the longest.
Old 01-05-2017, 08:44 AM
Rob, what type of motors, transmission/gear box, axle, and batteries did you use? Also what is the average run time of your 9620rx?
Old 01-05-2017, 11:54 AM
rc_farmer's Avatar
Master Builder
I am using a 55T motor with a 9t pinion coupled to a r2 tranny. The only space i had was for a 1250mAh 11.1 lipo. I need to take it apart and change the rear diff out to the new diff i bought. When i do, i will take some pic, may do i this wknd. I dont have an accurate run time yet, but all that weight shortens the run time on a hard surface. Haven't tried on carpet, kinda don't want to on carpet, because of the tracks. they are probably gonna throw and slip while driving on carpet as did on my combine. the slippage can be fixed by inserting rods in the spokes of the drive wheels.....just haven't done that yet.
Old 01-05-2017, 01:37 PM
scottyk scottyk is offline
Very cool, Id love to put my 3d printed snow blower on the front of that thing! Nice work looks like it runs very well.
Old 01-06-2017, 03:09 PM
Im currently using a 1550mah 7.4v which I inserted into the radiator to keep the detailed engine look goin. I had no problem with slippage, but I did add rods later on to the main drive wheels to help with pulling of implements on soil.
Old 01-06-2017, 08:26 PM
rc_farmer's Avatar
Master Builder
i put my battery in the diesel tank
Old 03-16-2017, 03:20 PM
deere9630 deere9630 is offline
deere9630 is on a distinguished road
That looks awesome!!
Old 11-23-2017, 03:07 PM
Fra23 Fra23 is offline
Fra23 is on a distinguished road
Eso se ve bastante bien
