Old 11-16-2016, 05:23 PM
crusher's Avatar
crusher crusher is offline
Default esc switch question
Hi, I have three esc's to run tracks and swing on my excavator, they each came with a small on off switch attached. Is this switch necessary or can it be eliminated by soldering two wires together and removing switch?
Terry
Old 11-16-2016, 07:47 PM
Default Re: esc switch question
The switches can be eliminated like that with no problem.
I would leave a switch installed on whichever one is powering the rx, just so the machine won't go live as soon as you connect a battery.
Also did you pull the red rx leads on the non-power escs?
Old 11-17-2016, 01:13 AM
crusher's Avatar
Thanks for your reply Frizzen, I did cut the redwire on all three, I have another esc for my pump motor that does the receiver charge.
Terry
