Old 11-18-2016, 08:38 AM
Jack3M Jack3M is offline
Jack3M is on a distinguished road
Default Need info on using wiper motors
I know at least 2 of you are using these for dozers. I am using them on a lawn mower, but I note under heavy work load they get way,way hot, like 170 or so by the time I get a thermometer on them.
Since they came with 18 gauge, I just ran 18ga from the Sabertooth 25 amp controller. The wires do not get hot. Not sure if by increasing wire diameter it will help or not.
So just how much weight can you push with these on dozers on the level? My mower is about 75-100 pounds and the hill is steep. On the flat no problem.
Wide open to suggestions and knowledge.
Thx
Old 11-18-2016, 09:03 AM
Default Re: Need info on using wiper motors
Rw has his geared down.
Mine are direct
drive and stall out with half a blade of dirt.
I never noticed them getting warm let alone hot.
I dont think rw has ever mentioned a heat problem.
Both dozers are in the 90 pound area
Old 11-19-2016, 10:02 AM
I put 40 tooth gear on output shaft so it runs max 3mph (according to numbers, which is close to reality). So essentially I did gear it down more, apparently not enough.
Waiting on others to chime in.
What wire size you use?
Old 11-20-2016, 02:00 PM
The stock wire , I soldered extra leads to them to reach the sabertooth
