Old 12-14-2016, 11:41 PM
roadranger's Avatar
White Line Fever
Default 6x6 questions
What is being used nowadays for powered steer axles?
Still using 1/10 size (wide) TLT/F350/Clodbuster axles, or are there narrower 1/14 power steer axles out there.
And what about Transfer Cases? Anything smaller/compact than the F350 tranny outdrive?
Thanks for any help!
WILDCAT T&C
Jim B.
Colorado Springs
Old 12-15-2016, 07:26 AM
Default Re: 6x6 questions
Look around ebay, there are various divorced t-cases that will work, ive used an axial transmission on my 6 X 6 as the T-case. If you want to keep the stock rear axles I believe the best way to go is the TLT steer axle. I didn't have an issue with it being wider, guess I didn't notice it was. There are some all wheel drive options out there if you want buy all new axles.
http://www.rctruckandconstruction.co...ead.php?t=9138
