Old 01-07-2017, 01:01 PM
Question AT9 Radio setup ?
I recently got a RadioLink AT9. I have it all set up with throttle, steering and 5th wheel unhooking servo working great. Now my question is on the (ch3)throttle stick it is mixed with channel 6 up and down and left and right operates ch.4. The opposite stick for steering operates only channel 1 left an right, up and down operates ch.2. How can I have the throttle only operate ch.3? I'm probably as confused as you are while trying to follow me. The truck lights will turn off if activated when I flip the transmission switch also.
I would like to have it all operating properly but I don't know my way around this type of radio setup. I would greatly appreciate your help. Thank you and I'll answer any questions the best of my knowledge.
Here's list of my channel set up:
Ch.1- steering, left and right, right stick
Ch.2- not used up/dwn right stick
Ch.3- fwd/rev(up/dwn) left stick
Ch.4- not used (left/right) left stick
Ch.5- not used, 2position switch F
Ch.6-not used but paired with ch.3
Ch.7- blank
Ch.8- lights, switch H, momentary switch
Ch.9- transmission, 3 position switch E
Ch.10- blank
Old 01-08-2017, 04:03 PM
Default Re: AT9 Radio setup ?
Never mind, after a few hours of jockeying channels around and then messing with the settings I finally figured it out. I had to eliminate the usage one channel/switch that was wreaking havoc across the board. Everything is working great and just how I wanted it to.
Sorry for wasting the time that everyone spent reading this.
