Old 03-01-2017, 06:02 PM
honda3 honda3 is offline
honda3 is on a distinguished road
Default RC4WD 360L
Just ordered the 360L excavator from RC4WD. I'm very excited about it and was wondering if any one has any experience with them? Also for anyone that has ordered from them before how long did it take you to receive your excavator or other heavy machinery?
Old 03-01-2017, 06:31 PM
Default Re: RC4WD 360L
Only took me a week to get my excavator from them and it was listed as out of stock at the time. Shipped directly from China.
LYNN
Old 03-01-2017, 08:30 PM
Good to hear. Curious as to what type of connector i need to connect my battery,Will a deans work or will an XT60 be necessary?
Old 03-01-2017, 08:47 PM
Northern Farmer's Avatar
Eagle's volvo excavator comes with female XT60 connection but if your battery is deans you can just cut and solder new connector either on model or battery. But don't cut both battery leads at same time. They also sell adapter plugs for basically every connection imaginable.
Old 03-02-2017, 07:27 AM
Sounds good guys i appreciate it
Old 03-02-2017, 05:24 PM
C-MurDaA C-MurDaA is offline
C-MurDaA is on a distinguished road
My excavator was ordered on a Tuesday, it left Hong Kong on Wednesday morning and was in NY ready to be delivered on Thursday! The only reason I got it on Friday was because a snow storm delayed it.
Old 03-02-2017, 10:09 PM
wow that is awesome man. On the rc4wd site it says it has shipped but i haven't received a tracking number yet.
Old 03-03-2017, 09:24 PM
avel avel is offline
Here is a four part video series on this excavator.
https://youtu.be/y7GBN4wAQrg
Youtube username iamaman27
Old 03-05-2017, 08:57 PM
What oil should i run and would i be able to get it around town?
Old 03-06-2017, 08:41 AM
grimms3 grimms3 is offline
grimms3 is on a distinguished road
Did you have to do bank transfer? I can't find anywhere to purchase those excavators using credit card.
thanks.
Old 03-06-2017, 11:17 AM
Rimrock Rimrock is offline
Oil was delivered along with the machine, separate bottle. Grade 22 or 32 works great.
Old 03-06-2017, 12:21 PM
yes bank transfer was required. Did you have to order the separate bottle or it was included with excavator? 22 or 32, does that refer to the weigh of the oil?
Old 03-06-2017, 12:26 PM
I just went with the recommended fluid RC4WD recommends/sells. I know it's not the best and is a bit over priced but just didn't want the battle if anything goes wrong that they won't cover it due to not using their recommended fluid. At least for the first few tank fill ups.
http://store.rc4wd.com/Mobile-DTE22-...oz_p_3843.html
Old 03-06-2017, 08:28 PM
I received it today and man these things are a beast! It came with oil so that was great. Can someone remind me what the screw cap does on the piece that resembles a filter?( the black stack sticking out of the engine compartment)
Old 03-07-2017, 03:00 AM
Adjust the pressure in the system, I think. I got that from the youtube videos.
Old 03-07-2017, 06:37 PM
Already busted one of the pads down low in between the pins, Are you able to drive the pins out? Is that the easiest way to change a pad?
Old 03-07-2017, 06:58 PM
lenny lenny is offline
lenny is on a distinguished road
did it look like shoty machining or casting or were you working it like a rental??
Old 03-07-2017, 09:12 PM
I believe i made a mistake on my end but I also believe the tracks could be made of a better material. Got in a proper first run today and man these things are just awesome.
Old 03-07-2017, 09:47 PM
Also can anyone explain what the dial on the black filter actually does. Im assuming its for pressure but what does turning it one way do vs turning it to the other way?
Old 03-07-2017, 11:46 PM
https://youtu.be/rXhqugrpBL4?t=1m49s
According to the video it adjusts the hydraulic pressure.
