Old 04-04-2017, 11:32 PM
honda3 honda3 is offline
honda3 is on a distinguished road
Default Hyd oil
Just curious as to what oil everyone runs and what size container they were able to purchased it in? Is hydraulic jack oil from an auto parts store suitable?
Old 04-05-2017, 12:50 AM
Northern Farmer's Avatar
Default Re: Hyd oil
I bought my hydraulic fluid at the local Cat dealer. Go with a 10WT hydraulic oil, doesn't have to be Cat.
Old 04-05-2017, 07:42 PM
Colin11123 Colin11123 is offline
Colin11123 is on a distinguished road
Default Re: Hyd oil
I use shell Tellus 15 in mine no problems so far
Old 04-06-2017, 07:04 AM
Dieselchopper's Avatar
Default Re: Hyd oil
Standard grade hyd oils work well. I have however switched over to canola oil. This was a result of blown hose in the house one evening. Difficult mess to clean up. Some of my play is indoors and oil leaks are a given at times. Regular house hold dish soap cleans up the canola oil. Cautionary tips on vegetable oil or canola oil. The water content laden in the oil will freeze and thus can cause damage. As well if not used regularly it will gum/gel up some. a little heat(hair dryer) will get things moving again. I usually change the oil after a unit sits more than 6 months.
