Old 05-02-2017, 09:03 PM
Default Switch & Fuse in Battery Circuit ?
I recently purchased a 4200XL ver 1.5 RC4WD excavator and someone recommended that I add an ON-OFF switch to isolate the battery (more convenient than unplugging all the time) and an in-line fuse for protection. I'm using a 6000mAh 3S lipo battery and am not sure how to calculate what amperage fuse and switch should be used.
Recommendations are greatly appreciated!
Thanks.
Old 05-02-2017, 11:15 PM
Default Re: Switch & Fuse in Battery Circuit ?
Not sure what that hyd pump has for amp draw, put a meter on it to see what it is & add 10amp cushion
Old 05-03-2017, 12:16 AM
What's your speed control rated at?
Old 05-24-2017, 11:23 AM
Lil Giants: Checked motor draw at hydraulic stall - it is 11A.
frizzen: Speed controller is rated at 60A.
So, a 20A fuse and switch should be okay for this?
Thanks for the help!
