Old 05-17-2017, 10:41 AM
Cat966c Cat966c is offline
Default Battery questions
Hi all! Been away for awhile. Anywho, I'm at the battery stage of my project and I need help (surprise). So I'm running a 12 volt rated pump and was thinking of getting an 11.1 volt battery, but the dimensions of it are too big. So I was wondering if I can use a 7.4 volt and still get decent power from the pump?
The pump is rated at 150psi at 12 volts.
Old 05-17-2017, 11:20 AM
Rimrock Rimrock is offline
Default Re: Battery questions
150 psi at 12V is a low rating initially. E.g in a excavator 300-400 psi is used to get a decent power. On a dozer it's more a matter of moving the dead weight of the blade and so on, so not as critical with the pressure as an excavator. you might get things moving at 7.4V, but not have to big hope of things moving fast) but it's no problem to give it a try, if you already got a 2S battery at hand.
There are lots of different sizes lipo 3s batteries out there, e.g ebay, would advice you to search for a suitable one.
Soyland Industrier
Old 05-18-2017, 11:36 AM
How about if it was an 11.1 volt battery? I've found one on eBay that's pretty compact
Old 05-18-2017, 12:01 PM
Northern Farmer's Avatar
Traxxas 11.1 1400mah lipo is fairly small.
https://www.amazon.com/Traxxas-Batte...s+1400+battery
Old 05-18-2017, 05:07 PM
That's the one to go for, that is the LiPo batteries with 3 cells, named '3S', mostly used these days for 12V setups. They are about 12.5 V fully charged, and one will typically recharge them when they have dropped to about 11.1V. A charger that is prepared for LiPo batteries is needed. And LiPo voltage alarm is needed, to hook up to the battery. If dropping the voltage bellow about 11V regulary, the lifetime of the battery will be relatively much reduced.
Soyland Industrier
Old 05-21-2017, 10:15 PM
trucker1970's Avatar
trucker1970 trucker1970 is offline
trucker1970 is on a distinguished road
I just bought a 10 cell 12v 2500mAh as a second battery and although it came in the wrong shape because I didn't see anything other than FLAT as an option I was able to get it to the configuration I needed and made it fit. It was $82.50 delivered... no clue if that's a good price I had a hard time finding one.
Old 05-21-2017, 11:58 PM
http://exceltruck-shop.fr/epages/3d8...bjectID=231242
