Old 07-17-2017, 05:02 AM
SA Pierre RC SA Pierre RC is offline
SA Pierre RC is on a distinguished road
Default Adding LED's Need some help
Hi
I want to add more led lights to my Tamiya trailer wiring set
There is 1 indicator and stop light for each side , I want to add 1 more indicator and 3 stop light for each side
thanks
Pierre
Old 07-17-2017, 06:12 PM
Default Re: Adding LED's Need some help
Should be able to just have your new LEDs wire in parallel to existing. Watch polarity, leds only work 1 way. You might have to change the current limit resistor if it's too dim after mods.
What part are you asking for help about?
Also, check out the thread at top of this section..
http://www.rctruckandconstruction.co...read.php?t=441
Old 07-24-2017, 12:14 PM
thanks for the response
I want to add extra brake lights and indicators
[ATTACH]Trailer2.jpg[/ATTACH]
