Old 07-22-2017, 12:04 AM
hareracing35 hareracing35 is offline
hareracing35 is on a distinguished road
Default Issue with my Grand Hauler... PLEASE HELP
Hey guys I'm having an issue with my grand hauler that I can't figure out.
everything on it works but i can't seem to keep it running, it will go for about 5-10 feet and stop running and the sound board will shutdown then fire back up again, but will still only go 5-10 feet no matter what gear i have it in.
if anyone can give me some insight it would be greatly appreciated.
thank you in advance.
Old 07-22-2017, 12:26 AM
Northern Farmer's Avatar
Default Re: Issue with my Grand Hauler... PLEASE HELP
May sound like a dumb question but are the batteries fully charged in both truck and transmitter ?
Old 07-22-2017, 12:49 AM
yes i thought that was the issue at first too but that didn't solve it
Old 07-22-2017, 02:02 AM
Disconnect everything from the rx.
Connect esc, try running. Connect a servo, try running. Connect another, try running... eventually something should cause it to act up, remove it again and see if it works ok.
Is the antenna ok and away from the motor?
Does motor have caps installed?
Old 07-25-2017, 04:27 PM
Rimrock Rimrock is offline
Don't know what electronics/sound you got, but if it's Tamiya MFC? There are issues if one got a steering servo that draws quite much power, the unit sometimes have issues dealing with it in combination with running the main motor. Also experienced issues when driving with heavy loads, when the MFC can't deliver enough amps, it just cuts and restarts.
Soyland Industrier
Old 07-25-2017, 11:22 PM
yes it's the tamiya mfc and i will try a different servo thank you
Old 07-26-2017, 04:25 AM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Also what radio and receiver are you using ?
Love my Kenworths
Old 07-31-2017, 12:21 PM
Berman's Avatar
Berman Berman is offline
If the battery hasn't dropped a cell (nimh), then my money is on the tamiya/molex plug.
4 tractors/trailers and still no king hauler...
Old 08-08-2017, 05:22 PM
swapped the servo i had in it for a basic s3003 and everything works fine now. thanks guys
