Old 07-23-2017, 06:34 PM
cosworth34677's Avatar
Default Rollers or slider?
I am having a time with this dozer build. I can't seem to get the tracks to run smooth. I am using the vex tank track kit. It works but the bogie wheels S straddle the chain in the tacks. And this was clogging up the tracks and causing all kind of problems. So I made a set of rollers and they didn't work well. So I will took off the roller and ran it and it seem to work the best this way. So....... do I try to make a new set of rollers or get some slick plastic and make a slider? I just need to keep the tracks from bunching up when reversing help please
Old 08-09-2017, 09:36 AM
carp carp is offline
Default Re: Rollers or slider?
check out rc loggers thread in the construction companies forum I'm pretty sure his dozer has fake rollers and the chain runs on a piece of delrin instead
Old 08-11-2017, 02:16 PM
Might have been puck board... it was a hard slippery plastic of some kind.
Old 08-11-2017, 02:49 PM
There are quite a few cutting boards made of delrin. Cheap and highly available that way, but you probably won't beat a plastic supply house on price.
If you have lathe access, you could even make rollers out of it.
