Go Back   RC Truck and Construction > Rc Truck's Q&A and Test section. > Test.
Test. Test your links and picture codes here.
Old 09-23-2017, 10:16 PM
Default testing 1, 2, 3, 4, 5, IDK
These Items are 3D printed?
Old 09-23-2017, 10:17 PM
Default Re: testing 1, 2, 3, 4, 5, IDK
I LIKE IT! NOT mine, just tried out a copy/paste to see IF Photobutt would let me see the pics!
Old 09-23-2017, 10:23 PM
[IMGhttp://i915.photobucket.com/albums/ac352/hofabooz/Leyland%20Truck%20Club/IMG-20161112-WA0027.jpeg~original[/IMG]
[/QUOTE]
Will this work AGAIN?
Old 09-23-2017, 10:58 PM
YET another
Originally Posted by siuvinson View Post
I've had this done for a few months and have posted it on other boards but never this one...so here it is! (LOTS of credit goes to SmallHaul...the drive and lift design was pretty much copied from his conversion )
Original "toy" form:
hacking it up to make way for drive/lift servos:
bucket tilt servos:
mounting wheels:
tinted plexiglass cab windows:
cab door:
amber strobe on the roof:
finished product:
forks?
Old 09-23-2017, 11:08 PM
~original MORE
Originally Posted by SmallHaul View Post
Old 09-24-2017, 12:31 AM
~original
Build time!
Old 09-24-2017, 12:34 AM
~original
Old 09-24-2017, 12:37 AM
~original
Old 09-24-2017, 12:39 AM
~original
That's it for photos.
I have a vid I'll post up.
Old 09-24-2017, 12:43 AM
NOT quoted for pics,...........but quoted for the INFO
I was asked for more info on this build and thought I would just post it up here for everyone to benifit.
Here is a parts list of what I used to build it:
Nomadio Sensor radio
Tamiya gearbox
2 x slotcar motors (tamiya motors are 3.5 volts and fry quickly)
Saber tooth motor controller
5 volt 5 amp (continuous) bec
Hitec Digital HS-7955 TG lift servo
2 x Align Digital DS410M servos for bucket curl
Old 09-24-2017, 12:47 AM
~original
Thanks Ben.
Thank you very much. I really enjoy the engineering challenge of getting strength & power out of these little machines.
I improved the bucket curl mounts. The mounts on the prototype loader work fine but, they don't like nice.
This design has more rigidity and protects the servos from getting hit:
With the servo screw heads milled down it allows the two servos (sitting back to back) to fit nicely in the lift assembly and creates a rigid assembly.
I also made beefier aluminum drive hubs. I'll post up pics later when I get the 4-40 screws that I ordered for them.
Old 09-24-2017, 12:53 AM
[/QUOTE]
quoted for INFO below here, NOT for images
Since I had to order more parts, I have a more accurate list:
Radio system
Tamiya twin motor gearbox
shims for tamiya gearbox assembly (you loose about 10 to 20% of gear contact on some of them if you leave them sloppy)
silicone to seal gearbox up (makes it last a very long time)
Aluminum stock to make drive hubs
4-40 screws & washers to secure gearbox to chassis
2 x hitec hs-5065mg digital servos for bucket curl
Hitec servo programmer
3" Y harness to join the 2 bucket curl servos
2 x 12" male servo leads to extend the bucket curl servos
heat shrink for all of the bucket curl servo wiring
piece of bicycle inner tube for lift lever cover (need to post pics)
4-40 rod and clevis for lift lever
lead weight
and 1 boat load of patience
Old 09-24-2017, 01:20 AM
[/QUOTE]
~original, it still works/
Old 09-24-2017, 01:21 AM
i like it
Joe, I can't find any pics of the beefier ones that I make now but, these are my prototype hubs that are on my prototype loader still. Just make the hub larger where the screws are so that you can make the 4-40 screws tight without worrying about striping out the aluminum threads. I also put flat spots on the axle where the screws hit.
Old 09-24-2017, 01:27 AM
more
Originally Posted by caterpillar View Post
Hi Joe, picture below. Hope it helps:
Old 09-24-2017, 01:28 AM
more more
Improvement made on the delta loader
Planning to sell it
Old 09-24-2017, 01:36 AM
~original
Originally Posted by motocrawler View Post
I have been really digging (no pun intended) doing these Bruder conversions, I am so impressed that with a little will and good equipment how functional these models can become. This time around I am doing a skid steer conversion...this was probably the hardest conversion I have done to date, mainly because of the size constraint of the model.
Step 1:
Cut out the back area for the the boom lift servo:
Step 2:
Make the bucket curl automation, this proved to be extremely difficult because of the various pivot points and size constraint. It was very hard to get a position where the bucket would curl all the way down and up:
Old 09-24-2017, 01:39 AM
~original
From there I went to work on the propulsion system. I used 298:1 geared motors soldered to the circuit board of a hi-tec continuous rotation servo. I then used a v-tail mixer from rc planes to be able to mix the motors in order to have a tank drive system.
I attached the drive wheels by use of a aluminum hub, I first filled the wheel with JB Weld so I had a way of mounting the hub.
From there I made the sprockets using zip ties-this method has been documented and used on several other conversions online (credit to smallhaul for this).
Old 09-24-2017, 01:42 AM
~original
MORE pics I wish to see, that Photobutt is holding ransom
Here are some final finished pictures and a video will come shortly. So impressed with how steep an angle it can climb. A few things I need to change to are: a more powerful lift boom servo and change the existing ESC to a castle creations 6V BEC so I can get max rpm from the gear motors and max torque from the servos. But beyond that it is highly functioning and so much fun to operate!
Old 09-24-2017, 01:50 AM
~original
YEP, MORE MOre More
Originally Posted by A.ash View Post
Gear box dirt protection
Lift servo installed (bottom view)
Curl servos mount build and installed
Electronics (minus Rx) and lead ballast installed
More to come
