Old 01-23-2011, 09:31 PM
Vanisle Vanisle is offline
Default ADT Project
I finally started one of my projects, an ADT based loosely on a Cat 350D. I am using 34 rpm / 139 oz-in gear motors from Robotshop and RC4wd MilSpec 2.2 tires.
I decided to make my own rims and hubs (using 2.5 and 1.25 inch aluminum round rod). The motors are longer than I thought so I had to make the rims offset. After much thought, I came up with a plan using a hub with set screw with the main rim bolted to the hub with ten 2-56 stainless hex bolts.
I had a little disagreement with a $20 2-56 drill bit - it wanted to stay in the hub and broke itself off to achieve this wish. I wasn't very happy but rather than go to the effort to get it out, I left one hole as a blank,
This is basically my proof of concept hub/rim and I need to make 5-6 more. Unfortunately, it could be a long time before I get back on this because I have real work to do.
Here are some slef-explanatory photos:
I have never used a lathe before and had no idea what I was doing. It isn't real pretty but it will work.
By the way, the lathe is for sale or trade in the buy and sell section (because I want a larger one to be able to work quicker).
Richard
Old 01-23-2011, 09:35 PM
Snochaser's Avatar
Default Re: ADT Project
Frickin' awesome!
I had to order some from Germany since I don't have that option. They look great!. Boy I'd love to buy your lathe you have for sale, but I have other needs at the moment.
Old 01-23-2011, 11:02 PM
Thanks Snochaser and RCLogger. I thought of buying some rims but did not know what I would need. I also wanted something that looked like it had planetary hubs. The nice thing about having a lathe and milling machine, I can make my own rims for about $4 apiece (and a whole lot of time).
It doesn't show up well in the other photos but the hub fits nicely into a bored out space so there is a lot of metal on metal contact between the hub and rim. I also put a slight indent in the motor shaft so the set screw will be more secure to prevent the hub from both spinning and pulling off the shaft.
The hub I showed is actually the second I did. The first one took two drill bits (broken off in the hub), one centre bit (broken off in the hub), a 1/8 end mill (broken off when I accidentally went the wrong way milling out the bits) and 2 dulled 3/16 end mills (milling out the end mill). I eventually got everything out and filled the holes with JB weld ... but what a pain.
I made a small attempt to get the broken bit out of the second hub but soon gave up and filled the hole with JB weld.
Here are a few more photos:
Old 01-23-2011, 10:55 PM
RCLogger's Avatar
RCLogger RCLogger is offline
looks good Richard
Glad to see your project is taking shape. Great idea making the rims and hub combination work with the motor. You will have more than enough power with those motors. I am looking forward to loading it up with dirt..
greg
Old 01-24-2011, 03:19 AM
A great start on an interesting project Richard.
Old 02-04-2011, 01:53 PM
RCLogger's Avatar
Must be time for a update Richard
Are all the rims done ? Its almost time to start sleeping in the shop cause spring is just around the corner. We need that ADT up and running. hahha
Get-at-her
greg
Old 02-04-2011, 10:26 PM
Not quite yet. I did get the rest of the rims turned and bored out (on the new lathe) but I stil have to do some milling on them and drill the hubs. I need to order some tubing for the axles and then I'll move on to the frame, etc. Unfortunately, the next 1-2 months are going to be pretty busy for me workwise. I shouldn't be spending any time in the garage ... but it's hard not to.
I've been busy tooling up the new lathe. It never seems to end.
Old 03-02-2011, 10:20 PM
RCLogger's Avatar
Any updates Richard ?
Old 03-03-2011, 06:22 PM
Well, umm, no. I have been buying some new machines (sold the old lathe and bandsaw and bought bigger ones), tools (darn Enco and MSC sales) and parts (transmitter, motors, ESC's, valves, etc) ... but no more work has gotten done. I am looking at late april before I have any time to myself. Yah late April looks good unless something comes up.
Old 03-03-2011, 09:42 PM
russisloud's Avatar
thats some very nice work on the rims and hub for a first shot
Old 03-04-2011, 12:19 AM
Thanks. What I lack in talent I make up for in tooling - I need all the help I can get in making parts. Sometimes it works out, sometimes it's a disaster. It's all fun though.
Old 06-25-2011, 05:09 PM
A small update on my slow motion ADT project. I made some axle housings out of aluminum tubing. I had to step the inside to slide in the gear motors for a nice snug fit. I will secure them with a couple of set screws - I wanted to be able to change the motors if needed. I also had to turn down the ends on the outside so the axle housing would fit over the rim.
My lathe DRO made it very easy to duplicate the parts. I also finished off the rims and hubs. Next step is to start the frame.
Here are some photos:
Richard
Old 06-25-2011, 06:32 PM
JensR JensR is offline
Great work, Richard!
35rpm sounds maybe a bit on the slow side? OTOH, it'll have pulling power to no end!
Old 06-25-2011, 07:13 PM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Hi Vanisle, Looking good.
JensR do you think this motors might work??
DC Motor: High Torque Mini 12V DC Gear Motor, 50 rpm
Old 06-25-2011, 07:35 PM
I don't remember exactly how I decided on this motor but I think I was looking at the speed in RCLogger's ADT and these were pretty close. I plan to run these on 13.2v batteries.
Old 06-26-2011, 07:58 AM
No, these are too small for Richard's large&heavy ADT.
Richard, you may well be right and you have 10% extra speed with 13.2V
As you already have the motors, I would suggest to just bolt/tie three or four (or all...) of them onto a wooden board and see how fast they go and decide whether this is acceptable to you.
Just my $0.02, hope you don't mind - for me it's always very annoying to have to change motors and I try to test as much as I can before I commit to a motor and mounting hardware.
Cheers
Jens
Old 06-25-2011, 09:29 PM
cbazq271 cbazq271 is offline
watching this closely. Looks great so far
Old 06-25-2011, 09:31 PM
If you need a Radio and or esc's, PM
Old 06-25-2011, 11:54 PM
Thanks for the offer. I think I already have everything I need (for this and a couple of other projects) ... but it has been awhile so I don't recall exactly what I had planned. One of the disadvantages of building so slow. Richard
Old 06-28-2011, 02:22 PM
35rpm sounds plenty quick for the gh motors' rpm -> what's the diameter of the tire?
What's the wall thickness of the tube to tap threads for the set screws? You gonna drill into the gearhead a bit too?
