Old 11-30-2017, 07:37 PM
crusher's Avatar
crusher crusher is offline
Default Track pad info needed
Hi I am still building my cat330d in 1/14 scale, I have #35 k1 track chain, can anyone enlighten me on pad sizes (width etc) for the above chain size?
This is my first scratch build, cut 84 pads on my manual mill before realising they were not going to work,( binding up.) I cut them from 1" wide aluminum, I cant just shave some off without losing the grousers.
Thanks for any help you can offer.
Terry
Old 12-02-2017, 04:37 AM
Default Re: Track pad info needed
Check out SmallHauls' doepke Unit Cable Hoe thread, it uses #35 chain with k1 every other link. I believe he mentioned using carpet edge transition for pads.
http://www.rctruckandconstruction.co...ght=Cable+unit
Photobutt ate the pics, so you'll probably need the browser patch to see them
I think rvjimd also used that chain to run pads on version one of his Ny-lint michigan C-24 crawler base.
If that doesn't help, i think there were a couple Dozers running the chain too, and they had to make more gap between pads to let dirt fall out.
Post a pic of your setup.
Old 12-02-2017, 03:14 PM
crusher's Avatar
Thanks for your reply Frizzen, the gap around the idler and drive sprockets is what i am trying to minimize, I was kind of hoping to hear from the guys who have printed off the pads with their 3d printers as i have just purchased a printer myself.
Thanks again
Terry
