Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > RCP’s Aluminum Gravel Boxes and Accessories
RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more
Old 12-19-2017, 09:48 AM
Default Super Dumper
I've been hammering in a lot of hours on this to get it shipped out before Christmas. It's at the powder coating shop now so I thought I would post a couple of build pictures. Bigford built the tractor so he's the guy to ask questions about that part of the build if anyone has any.
Old 12-19-2017, 10:29 AM
Default Re: Super Dumper
Why so many axles?
#shouldhavebeenatrailer
Old 12-19-2017, 11:37 AM
Why so many axles?
#becauseyoucan
Unique and interesting truck
Old 12-19-2017, 11:39 AM
Bigford, Do you intend to have the rear axle hanging off the backside of that thing?
Old 12-19-2017, 12:50 PM
Nope built just like the 1:1 is
Old 12-19-2017, 04:53 PM
ditchdigger ditchdigger is offline
ditchdigger is on a distinguished road
So the scale box length is 24 foot?
Old 12-19-2017, 06:39 PM
Northern Farmer's Avatar
Awesome job as always Reg Well earned break!
Old 12-20-2017, 04:57 PM
WOW! Just simply...... WOW!
Outstanding build
Old 12-20-2017, 10:06 PM
Reg got the box back from the powder coater
Old 12-21-2017, 05:38 PM
I'm anxiously awaiting to see how well you like that hyd multi stage lift ram for the dumper. I've thought about one, but am leery of pulling the trigger on the purchase. I just haven't seen them in use enough to know for sure how good they are.
Old 12-21-2017, 06:14 PM
It's a nice cylinder seems strong enough and with a good
Pump it will definitely lift any thing I toss in the box.
I think reg said it a 45° dump angle could have used the 550mm cylinder instead
https://youtu.be/S9G3nc-i3mQ
Old 12-21-2017, 07:26 PM
Any idea how much weight it's capable of dumping?
Old 12-21-2017, 08:20 PM
It should lift a lot given the bore size of the first stage. Of course that all depends on the pump used but I don't think it will have issues dumping a heaped load.
With this cylinder it has about a 40 degree dump angle. Not super steep but enough for gravel or dry dirt I think.
Old 12-21-2017, 09:24 PM
Off the rcbmim site. Take it for what it's worth
Capacity : 80 (ML)
Rated pressure : 2 MPA
Maximum pressure : 5 MPA
Theoretical Thrust :Theoretical lifting force 110KG (first section
Old 12-22-2017, 02:26 AM
110KG, first stage, so slight loss(es) as each stage raises......I'd bet it'll lift 24-30 pounds with no problems, if not more.
Old 12-23-2017, 03:15 AM
For non sticking materials, it will work. My 1:1 Mack only goes to 42 degrees, sometimes it isn’t enough! Even with a vibrator.
Cheer’s, Neil.
Old 01-07-2018, 10:06 PM
The super dumper is just about ready to go to cabin fever this weekend
Definitely not enough time to wet sand the last coat
Of paint and clear before the show. I'll let it ride until the
Spring.
Old 01-08-2018, 03:21 AM
Lmackattack's Avatar
nice did you get the lift system working yet?
MACK
"The Greatest Name in Trucks"
Old 01-08-2018, 08:09 AM
Sped74's Avatar
Sped74 Sped74 is offline
Sped74 is on a distinguished road
that thing is looking great
Old 01-08-2018, 11:28 AM
Looks fantastic!
