Old 02-06-2018, 10:18 PM
Cat966c Cat966c is offline
Default Battery stuff
Okay; I was going to put this in the electronics section, but the last update there is 2015 ��
So; I bought a turnigy nano tech 7.4v 3000 mah battery and it says it’s a receiver pack but I was wondering if it would work as a main battery for the loader??? I don’t see why it wouldn’t.
This is it: https://www.walmart.com/ip/RC-Turnig...&wl13=&veh=sem
Old 02-07-2018, 12:27 AM
Default Re: Battery stuff
Which wheel loader? It should be fine. Only difference is thinner wires and jst style plug which we all resolder with different kinds.
Old 02-07-2018, 03:33 PM
Thanks. The 966 I’m making. It’s in 1:14
Old 02-07-2018, 07:09 PM
Thanks for the reply. However now I need to know if the bullet connectors on the m3 hydraulic magom pump would work with these female bullets on this esc
https://m.ebay.com/itm/30A-Brushless...10&_mwBanner=1
Old 02-07-2018, 07:25 PM
Best advise I can give, is to mic them & the one that you intend to use with it. If they DON'T fit together, bullet plugs can be found inexpensively on Evilbay. They're not that bad to cut off, & solder new ends onto them.
