Old 03-03-2018, 05:40 PM
jearbear0927 jearbear0927 is offline
jearbear0927 is on a distinguished road
Default Transmitter...
Can a person completley change the type of switch on a transmitter? *ie from a 2 way to a 3 way? or from a vr to a 3way? if not whats my best option for a transmitter with alot of 3 way switches? budget friendly pls. thnx in advance
Old 03-05-2018, 01:29 PM
ittigger ittigger is offline
ittigger is on a distinguished road
Default Re: Transmitter...
You could physically put a 3 way switch in place of a 2 way, but it would still be a 2 way switch because the 3rd circuit is missing. A 'good' transmitter with alot of 3 way functionality will most likely not be budget friendly as you're asking for more options.
Old 03-05-2018, 02:30 PM
Yard Toad Yard Toad is offline
Yard Toad is on a distinguished road
I upgraded to a Radiolink AT9s not a really expensive radio but has 3 three position switches 2 variable knob and 3 two position along with 2 sliders. Radio has plenty of functionality for the money also has lots of pre programed mixes and room for custom mixes. Look them up.
Old 03-05-2018, 03:01 PM
Why not pay a little more & support a company from your own country, instead of sending more money to china? Spektrum DX9 has several 3pos, sliders & a knob, you can channel assign any switch as you like, and several mixes & F modes too. It's very user friendly, easy to program.
Old 03-05-2018, 05:00 PM
Wombii's Avatar
Wombii Wombii is offline
The Taranis Q X7 is a cheap 16 channel radio using the OpenTX open source firmware. It allows you to swap out any switch to 2 / 3 / multi position and assign channels, flight modes, mixes or custom functions to any switch. It is however NOT what I would call user friendly or easy to program. Expect to spend some time watching tutorials on youtube if you get one
Old 03-05-2018, 06:06 PM
Some radios are wired for 3 pos, some aren't.
When i first got into rock crawling it was a common thing to pop open a traxxas TQ3, change the thumb rocker to a toggle. All the wiring was already to the switch so it was quick and easy.
I've also cracked open some that don't even have any pads at the board to make it happen.
