Old 03-04-2018, 03:39 PM
Default Wheel Modification
I have started work on building a model of a truck I used to operate many years ago. I am trying to make it as true to the original as I can. The original truck had painted wheels instead of fancy chrome wheels. The company, a utility, wasn't about to spend any money on flashy chrome. So knowing they were going to be painted I got a set of standard white plastic Tamiya wheels. These are the standard wheels that come in every Tamiya truck kit but haven't been chromed. These wheels also have the advantage of being very cheap. The original truck I am modeling had Budd style 2 hole rims. Looking at the 9 hole Tamiya wheels, I wondered if I couldn't modify them to look like the originals. This is the process I came up with.
The easiest way I figured would be to glue plastic plugs into the existing holes, sand them flat with the surface of the wheels and then drill new holes. Upon measuring the hole size I discovered they were just a bit smaller than a 4mm rod would fit into. So I had to turn down some rod and make plugs to fit into all the holes. 10 wheels x 9 holes per wheel = 90 plugs to make! Can you say tedious? Actually made about a hundred to allow for goofs.
These two photos show front and back of a wheel with the plugs glued in place.
I learned that you can't rely on capillary action to pull the cement into the joint. Maybe I made the fit a little too tight? I had a few plugs come loose during the course of machining and sanding and had to redo those wheels. I used Plastruct Bondene as the cement. Make sure to apply to the sides of the plugs before inserting them into the holes.
Next step was to get the ends of the plugs even with the surface of the wheels. The tricky part here is that the surface of the wheel is slanted where the holes are and the new plugs would have to match that slant. I thought the easiest way would be to chuck the wheels up in the lathe and turn the plugs down using the compound rest to match the angle of the slope. I estimated that the angle was about 12 degrees. There is not a lot of room inside the wheels, and I didn't want to damage the cast in place lug nuts, so a small tool would have to used. I first used a 1/4” threading bit. This fit in the area ok but was difficult to get a smooth cut as the next photo shows.
I then tried a narrow parting tool and that worked very well, making for a pretty smooth surface on the soft plastic. You may note that the tool bit in the above photo is upside down and cutting on the back side of the wheel. This is an idiosyncrasy of the Sherline lathe. Works well once you get used to working like this.
After flattening the plugs, the next step was to cut the new holes. I used my mill for this step but a drill press would have worked as well. While a rotary table is really helpful here, careful measuring and spotting without one could also be done. My mill does have CNC capability but I used it only to control the positioning of the rotary table. Didn't think it was worth the effort to write a program for this work. The next two photos show the milling of the new slots.
After all the wheels had their new slots cut they were all put back on the lathe and then sanded. I used angled sanding sticks through 600 grit to get the surfaces completely smooth and ready for priming and painting. Next photo shows one pair of the newly revised wheels next to a pair of the originals.
After the sanding it was off to the paint booth with them for priming, painting and detailing. Next photo shows the completed wheels with tires installed.
Why the original truck had silver rear wheels and black front wheels I don't know, just the way it was. All in all I am very happy with how they turned out and thought that others might want to see this method as a way to inexpensively modify wheels for their truck projects.
Oh, one last note. When cutting the slots in the front wheels it was necessary to cut completely through one of the support ribs on the back side of the wheel otherwise it would show in the slot. Since there are 9 holes in the wheels they are asymmetrically spaced. In other words you can't cut two holes 180 degrees apart in these wheels without hitting one of these ribs. No more weight than will be placed on the front axle of this truck I don't think this will be a problem. If you are going to build up a heavy hauler then you might want to take this into consideration.
Old 03-04-2018, 03:43 PM
ramjetexpress ramjetexpress is offline
ramjetexpress is on a distinguished road
Default Re: Wheel Modification
Awesome , man oh man I wish I had those skills and that machine as well .
Old 03-04-2018, 03:48 PM
Nice work
Old school modelling, minus the Sherline machinery
Old 03-04-2018, 05:40 PM
gismow's Avatar
gismow gismow is offline
Cool work, nice done...
Greetinx
Peter
Old 03-04-2018, 06:13 PM
That's really impressive! They look great.
I have 1 question though, wouldn't it have been easier to just make the holes getting plugged 4 mm rather than turning down 100 sections of plug rod?
Old 03-04-2018, 08:17 PM
Thanks for compliments guys, they are appreciated.
I did consider that option but felt that trying to line up that many holes to be able to consistently center drill them all out would be just as trying. I would still have to make all those plugs anyway. Once I had the cutter on the lathe set to the depth of cut I needed it really went fairly quickly. Only had to make a single pass of the cutter for a few millimeters, hit the rod with a fine tooth cutoff saw and on to the next. Probably only took a little over an hour to make all the plugs.
Old 03-05-2018, 03:28 AM
Very cool scratch building skills right there.
I would have taken the easy way out and bought these
Old 03-05-2018, 06:43 PM
Those wheels were actually what I thought I was going to get when I first started to think about building this truck. I'd seen them on other trucks and really like the look of them. Then I saw the price of them and knowing I was going to have to remove that pretty white finish on them in order to paint them the color I needed and no, decided I needed to go another route. All ten of the white plastic rims I bought were less than $20. Less than a dollar for the plastic rod and cement and I was in business. Besides, for me, a big part of the fun of this hobby is figuring out how to make the parts I need and then making them.
Old 03-04-2018, 06:27 PM
That's AWESOME! Great work doing those, they look good.
Old 03-06-2018, 05:56 AM
I would have made it half way through the first
Rim. lost my mind and chucked it across the garage
My hat off to you
Old 03-06-2018, 06:00 AM
Hostile Hostile is offline
Haha what bigford said.
Great and simple way on a budget. Also, looks simple enough thanks to your step by step pictures. Well done!
