Old 07-25-2018, 12:57 AM
Lifted98 Lifted98 is offline
Lifted98 is on a distinguished road
Default scratch built D11 130pounds
my D11 dozer my dad and I built this past winter 130 pounds blade is 24 inches wide just to give an idea of size. the Cat still has custom decals and lights that have yet to be installed . the cab over semi seen in the one pic is a full custom (my dad made the cab). the two dump boxes are also homemade minus the chassis.
File Type: jpg 20180501_160311_zpsobstorue1234.jpg (157 Bytes, 470 views)
Old 07-25-2018, 09:01 AM
Default Re: scratch built D11 130pounds
Awesome models!
Old 07-25-2018, 10:18 AM
scottyk scottyk is offline
wow! nice work, that thing looks like a beast
Old 07-26-2018, 12:00 AM
Thanks it was alot of work and a lot of research to get it this far .Its currently being modified to have full blade fuction i also just swapped out the 12 volt agm battery for some 14.8 16000mah lipo batteries now i can go for 1.5 hours on a single charge !
Old 07-26-2018, 10:24 AM
Were did you get the 16000 mah lipo batteries?
Old 07-26-2018, 10:28 AM
Were did you get the 16000 mah lipo batteries ?
Old 07-26-2018, 12:25 PM
Just a website called hobbyking was 64 dollars cad so bought 2 seem to work just fine
Old 07-26-2018, 12:29 PM
Would anyone know who to talk to about a planetary gear reduction fot the drives would be nice to use a larger sprocket ?
Old 07-28-2018, 12:40 PM
I LOVE IT! Thanks for the build pics that you included with it. That machine looks good
Old 07-28-2018, 06:29 PM
I can post more pictures in its early build stages later on this weekend when i get infront of a computer .
Old 10-07-2018, 02:02 PM
Old 10-07-2018, 02:03 PM
Old 10-07-2018, 02:09 PM
Old 10-07-2018, 02:11 PM
Just a few more build pics as well as the lights that were just put on decals will be the finishing touch.
Old 10-21-2018, 12:28 PM
jimkidmotorsports jimkidmotorsports is offline
jimkidmotorsports is on a distinguished road
how long did the 12 volt battery last im building one now using a car battery nicebuild looks awsome how does it well does it push in the dirt jim
Old 10-22-2018, 05:49 PM
I used a agm 12 volt 18 ah agm battery lasted about 45 min but had very low power to push dirt it was fine to push snow but that's about it .what I found is that when I test the voltage at each motor with a sabertooth 2x25 I was only getting 6.7 volts to a motor . I would recommend to find some large higher voltage lipos turned my dozer from being a turd in the dirt to having all the power I need plus it last twice as long with out such a drop in power as the battery gets low.
Old 10-22-2018, 05:52 PM
It will easily push a full blade of dirt( about 24 inch blade) easily but that's with the lipo 14.8s with the lead acid or agm 12 volt it struggled I would recommend a gear reduction just to slow it down a bit
Old 10-22-2018, 10:31 PM
https://youtu.be/QuSZJ-r1Q0E
Old 10-22-2018, 11:52 PM
https://youtu.be/LPzGgp-QASw
Old 10-23-2018, 12:40 AM
https://youtu.be/CGZ7BxYrVqg
