Old 05-22-2019, 01:56 PM
Lord_Fabricator's Avatar
Lord_Fabricator Lord_Fabricator is offline
Lord_Fabricator is on a distinguished road
Default Question about hydraulics and speed
I have a large truck I am building, which due to weight, I intend to put hydraulic steering on. The pump I have is 140cc/minute flow rate, and each of the 4 pistons is 10cc, obviously that gives me a very slow travel speed for the pistons, with 10 seconds to go from full-speed to the opposite.
I read about hydraulic accumulators and was wondering if anyone has had any experience in that area.
The Lord Omnissiah gifts all who follow the Machine. Some he gifts limbs of gold, some he gifts tongues of fire. Me, he gifted with a brain of silicon and copper.
Old 05-23-2019, 11:10 AM
Default Re: Question about hydraulics and speed
Hydraulic steering is interesting. Not clear by your description of "each of the 4 pistons is 10cc". How many cylinders are steering and what is bore & stroke of them? How do you plan to plumb the circuit - what components are you using?
Old 05-23-2019, 02:23 PM
4 cylinders, 10mm bore, 4mm shafts, 30mm stroke. 4mm hose coming down the upper links. The pump only has a 140cc flow rate. All four pistons are on the same valve.
Old 05-25-2019, 10:33 PM
Maybe what is throwing you off is the 140cc/min verses the cylinder size in millimeters. 1cc = 1000 cubic millimeters. A 10mm x 30mm cylinder has a volume of 2355 cubic mm x4 cylinders is 9420 cubic mm. The pump delivers 140,000 c mm/min, so all cylinders could extend fully in less than 4 seconds. In a typical steering setup, pairs of cylinders work opposite of each other - one extends, one retracts - reducing the total volume needed since the rod side has a smaller volume. I would think steering speed should be acceptable since seldom do we need to turn lock-to-lock. Does this help? Let me know if I've misunderstood your specs or needs.
Old 05-27-2019, 02:19 PM
I see...I did my math very wrong...I forgot to convert...so yeah, that's plenty fast enough. Thank you.
Old 05-29-2019, 12:34 AM
And now I have another question: Hydraulic lines with T-couplers in them. Does anyone do this and/or know where I can get 2mm T-couplers? I have 4 sets of pistons running in parallel, and would like to do that with a single valve, instead of a whole bank of valves.
Old 05-29-2019, 03:16 AM
Papy Papy is offline
You can probably order directly from SMC or find a local dealer
Here is the link to the SMC / M fittings catalogue which suits perfectly our activity.
PMD/Garden trucking also offers a wide range of smaller fittings and various accessories you could use for such small cylinders
Old 05-30-2019, 02:34 PM
Thank you, I'll have to look into that when I've got my actual computer to do the order.
