Old 05-24-2019, 07:13 PM
Mech_Eng's Avatar
Mech_Eng Mech_Eng is offline
Mech_Eng is on a distinguished road
Default Fumotec PC 490
I ordered this kit last August and it arrived around February. I'm just not getting started on it. Frank says I have the only 490-11 in the entire state of Texas! I have been posting progresss on FB and am much farther along than my current posts but photo hosting has been a bit of an issue......
I started with pressing track pins:
find the nearest chevron
Old 05-24-2019, 07:33 PM
Mech_Eng's Avatar
Default Re: Fumotec PC 490
Next, I started to assemble the undercarriage. Both ESC's for the brushless track motors are stored here. Im using ESC's by Castle Creations and so far I like them quite a bit! It looks like a mess here but I got it cleaned up......somewhat
Old 05-24-2019, 07:38 PM
Mech_Eng's Avatar
After I got that the undercarriage wrapped up, I started on the upper half.
Old 05-24-2019, 07:51 PM
Mech_Eng's Avatar
next I started setting up the valves. I bought cheap servo's, does it make a difference as far as control?
Old 05-24-2019, 07:53 PM
Mech_Eng's Avatar
Then I put the boom together. I did not take many pics and it was not pretty! If I had to do it all over again, I would have ordered reamers in the 3 sizes required..... I got it done thought
canara atm near me
Old 05-24-2019, 07:59 PM
Mech_Eng's Avatar
And then...... the plumbing started:
Old 05-24-2019, 08:02 PM
Mech_Eng's Avatar
Then I started on the details.... These 1.3mm fasteners are not for the faint of heart. I pre drilled 1mm holes, cut the screws and said prayers... it worked out, mostly...
Old 05-24-2019, 08:06 PM
Mech_Eng's Avatar
And then I got the guts moving with no leaks so far..... My new problem is setting up my Spektrum radio.... These valves seem to have a pretty wide center and after that, i'm lost... Currently running a DX7 and have the 2 accessory valves disabled until I can get a new radio....
capital 1 bank near me
Old 05-25-2019, 03:35 PM
The servos, depends how smooth they rotate & how quick they respond.
As for radio, a DX9 would be best, slides on the back for the tracks.
Looking good so far.
Old 05-26-2019, 03:33 PM
calum_scania's Avatar
Looking good, this is part I hate most! Trying to squeeze 8 pipes neatly in there without any kinks is a nightmare!
Did you not opt for a quick coupler?
Calum
Old 05-26-2019, 08:30 PM
Mech_Eng's Avatar
Calum
I plan to add it at some point. I need a radio with enough channels first....
I've been enjoying your build thread, very helpful to me!
Old 05-27-2019, 05:18 PM
Ah, I use a graupner MC20 - seems a decent enough transmitter
The DX10 was another option when I was trying to decide, but thats a few years ago so there's probably alternative options
Yes its good to see other fumotec owners work to check you're doing it right
