Old 06-03-2019, 01:09 PM
pedrcri pedrcri is offline
pedrcri is on a distinguished road
Default Bruder D5 and Bruder Delta conversions
Hey Guys,
I have converted these 2 Bruder toys to RC. I used some of every conversion and made my own based on what I thought would work best based on what would work. I am still working on getting the delta to work 100% but for some reason the lift arm keeps coming down when I raise it. The bucket curls and stays in position. I did modify the servo to be continuous for both but the lift seems to keep falling. does anyone know what might be the issue? I think the BEC might be part of the reason but I am not sure. your ideas would help. I also made a Youtube channel about the life of an RC construction crew. hope you guys like it and can comment on it.
here is the link https://www.youtube.com/watch?v=UJo3DYCm62E&t=8s (edited with new link)
My next conversion is a John deere 7930. I will try and post that build.
thanks again.
Old 06-04-2019, 08:02 AM
kaptain Jack's Avatar
Default Re: Bruder D5 and Bruder Delta conversions
Sounds good. Make sure to take lots of pictures!
Old 06-04-2019, 01:26 PM
I will. I am waiting on my parts to come in from Robotshop. Then I can start taking things apart. I will show step by step.
Old 06-05-2019, 02:48 PM
Thumbs up Re: Bruder D5 and Bruder Delta conversions
so looks like the link to the youtube channel did not work. here is the correct link.
Old 06-05-2019, 06:39 PM
Can't wait to see your take on converting those.
(So i can see what ideas to copy)
Old 06-06-2019, 02:12 PM
I did convert the D5 and Delta. I will do a video showing how I made them. for the delta there is a build already you can follow.
https://www.rcsparks.com/forum/threa...dded-pc.36063/
Still waiting on parts to start the John deere 7930.
Old 06-19-2019, 11:32 AM
I started the build on the 7930. its the breaking down of the machine. hope you enjoy and if you have any questions let me know.
Old 06-19-2019, 11:35 AM
build is up! go check it out..
https://rctruckandconstruction.com/s...ad.php?t=13480
Old 07-01-2019, 10:05 PM
O like that you let us know where them pesky locking tabs are mounted at.
Old 07-03-2019, 02:18 PM
Its impossible to know where all of them are without destroying the whole model. hope it helps.
Old 07-07-2019, 11:36 AM
Chipsky's Avatar
Chipsky Chipsky is offline
Chipsky is on a distinguished road
I was looking to follow your lead on the Skid Steer... do you have a wiring diagram. I can piece together a lot of what you did from the RCSparks post, but not all of it. Let me know and great job! =)
Old 07-09-2019, 11:53 AM
Let me draw it up today and I can take some pictures as well so you have reference. Keep in mind I converted the servos to be continuous so that I can have that hydraulic stick movement. only issue is that the arm does not stay in position as it falls from the weight. I am still trying to figure if I need to change the end points or do something different.
Old 07-15-2019, 11:23 AM
Hey Chipsky,
sorry for the delay but here is the layout for the electronics. you might have to reverse one of the motors on your transmitter or the wires to the sabertooth. but other than that its pretty much setup. also, you can make some adjustments on the speed if your transmitter allows for those changes. let me know if you have more questions.
Old 07-21-2019, 06:34 PM
It very much helps. Thanks so much!
Old 07-23-2019, 02:54 PM
THe John deere is all done check this out!
quick video of the lights and beacon
https://i.imgur.com/4xu7rEz.mp4
Old 08-15-2019, 03:28 PM
does anyone have a 3D print or alternative to the tracks for the Bruder D5? I have been looking for something to replace the tracks so that the track had a pin instead of the plastic which the sproket connects with when spinning.
thanks for any help.
Old 08-19-2019, 05:09 PM
Chipsky's Avatar
Hey Chipsky,
That looks good and is very helpful!
Tags
bruder
