Old 06-20-2019, 04:34 PM
ittigger ittigger is offline
ittigger is on a distinguished road
Default Programming Radio Switches
Does anyone know how to move a stick function to a switch - example, on a 1/14 scale rig, to move the 3 speed to a 3 position toggle? Would this not allow the mfu to work properly?
or to move the light, horn or other function to a toggle?
I understand how to 'mix' (DR/Expo) stuff to a toggle, example:
normal stick is 60% and with toggle, it's 100%
I have a Spektrum DX6i and a Futaba T8J that I'd like to move functions from the sticks to toggles.
Current setup (https://rctruckandconstruction.com/s...722#post163722)
------------ Previous Post Below --------------------------------------
I have figured out a resolution to the Start / Stop with Spektrum DX6i:
Steps
D/R Settings:
ELEV - with Elev D/R in position 0 (set it as follows):
ELEV 0 | 60% | INH
Change Elev D/R to position 1
ELEV 1 | 100% | +40%
RUDD modification: which allows for the Start / Stop functionality:
RUDD 0 | 60% | INH
Change Rudd D/R to position 1
RUDD 1 | 100% | +40%
-------------------------------------- Step By Step Instructions ---------------------------------------------------
a: Scroll down to D/R&EXPO and click.
b: Scroll through to the first column next to ELEV is selected, and click.
c: Ensure the ELEV D/R switch is set to 0, there should be a 0 next to ELEV on the screen.
d: Change value to 60% using the scroll wheel and click.
e: Move the ELEV D/R switch on the Transmitter from 0 to 1, there should now be a 1 next to ELEV on the screen.
f: Back on the screen, ensure that the first column for ELEV is set to 100%
g. Move the scroll wheel to the second column of ELEV and click.
h. Change the value to +40% and click.
i. Move the ELEV D/R switch back to 0 from 1, there should now be a 0 next to ELEV on the screen.
j. Scroll through to the first column next to RUDD is selected, and click.
k. Ensure the RUDD D/R switch is set to 0, there should be a 0 next to RUDD on the screen.
l. Change value to 60% using the scroll wheel and click.
m. Move the RUDD D/R switch on the Transmitter from 0 to 1, there should now be a 1 next to RUDD on the screen.
n. Back on the screen, ensure that the first column for RUDD is set to 100%
o. Move the scroll wheel to the second column of RUDD and click.
p. Change the value to +40% and click.
q. Move the RUDD D/R switch back to 0 from 1, there should now be a 0 next to RUDD on the screen.
r. Scroll until List in the top right hand corner is selected, and click.
Save settings and exir programming mode
------------------------------- End Of Step By Step Instructions ---------------------------------------------------
Make sure all toggles are set to position 0 and go through the MFU setup again.
1: Press and hold the MFU 'Set' button for 1 second, MFU should stop engine the control box will blink.
2: From the Transmitter, move the left stick completely up & down then to center and wait. The LED on the control unit will blink 3 times.
3: Move the left stick completely right & left and to center. Again, the LED on the control unit will blink 3 times.
4: Move the right stick completely up & down and then to center. Wait for the LED to blink 3 times.
5. Move the right stick completely left & right and then to center. This time, the LED will blink 3 times quickly, and then will blink slowly.
6. Press the Set button on the control unit, the LED will then blink and turn on.
Using the Transmitter, I now have:
Elev D/R in position 1
a: Throttle is left stick - up & down.
b: Steering is right stick - left & right.
c: Changing gears is left stick - left & right.
d: Long horn is right stick up.
e: Short horn is right stick down.
g: To turn on / off the hazard lights, move right stick up
h: To get through the light functions, move the right stick down.
Elev D/R & Rudd D/R in position 1:
i: To stop / start the engine, put the left stick in the left position and the right stick to the up position.
Gear Toggle:
i: To operate the Fifth Wheel / Landing Gear, use the Gear toggle switch.
I have confirmed the start / stop resolution works for the Futaba T8J radios as well. I don't know what the effect of the change is to other operations (if any) but I know that start / stop now works - as well as all other operations.
------------ Previous Post Above --------------------------------------
Is there a way to assign these 'functions' (lights, start / stop) to a toggle switch?
