Old 07-24-2019, 08:18 PM
Texasperry's Avatar
Texasperry Texasperry is offline
Texasperry is on a distinguished road
Default Tamiya Trucks for conversion.
I have seen a lot of dump trucks made from King Haulers.
I am thinking of using a Ford Aeromax. Are the frames the same on all Tamiya trucks the same.
Perry
Old 07-24-2019, 08:23 PM
Default Re: Tamiya Trucks for conversion.
all dimensions except length, and location of holes
Old 07-25-2019, 01:42 AM
Wombii's Avatar
Wombii Wombii is offline
https://www.tamiya.com/english/rc/manuals.htm
You can find manuals for some of the trucks here. They show drawings of the frames so you can compare hole locations. Usually the groups of holes are similar, but spaced differently depending on length of the truck and type of cab. If you want to make custom length frames, you can use 3mm + 2.5mm drill bits and an M3 tap and an original set of frames as a guide.
