Old 04-14-2020, 01:11 PM
malawicarsten malawicarsten is offline
malawicarsten is on a distinguished road
Default Leimbach pistons repair on 966G
Hi
I got hold of some repair kits for my Leimbach pistons on my Wedico 966G as they are leaking badly with oil.
Anyone ever tried to fix these as I can't find any guides or similar online?
Best Regards
Carsten
Old 04-21-2020, 04:25 PM
Actros4160's Avatar
Default Re: Leimbach pistons repair on 966G
I did my Cylinders and valve overhauling after 10years on my Cat345 and I needed to send this to Thicon-Models in Germany because Leimbach would not deal with foreign country's.
Bernd
Old 01-22-2021, 06:19 PM
I'm in the same situation. My 996g is leaking on one of the steering cylinder. It's a newer production machine with very little use too. I had a second older 966g machine with a very early production # and that did not leak at all... go figure.
So any info on how to proceed with rebuilding would be appreciated.
Old 01-23-2021, 07:20 AM
Check with PMD Gardentrucking, they might have the repair kit from Leimbach with the different o-rings needed.
Old 01-23-2021, 07:24 AM
As for opening them, you should remove all fittings and put it in a vice, then gently twist the top/ top part off.
Old 01-23-2021, 12:37 PM
Thanks all. Joe also gave me a few tips and mentioned leimbach uses glue to seal the top cap. Has anyone found a source for the orings?
Old 01-23-2021, 01:58 PM
Hi
The numbers I know are:
30186-W or EHZW006 for steering cylinders
30188-w or ehzw007 for lifting arms and the showel tip
Numbers are from my empty bags I saved in case I needed more.
On bag the ehzwxxx seems to be leimbach number and the other from THicon
