Old 06-11-2020, 01:41 PM
cosworth34677's Avatar
Default Alternative to hydraulics In my dozer.
Hey any one got some ideas to replace hydraulics in my dozer ? I'm thinking I can get away with something other then hydraulics. Just looking for ideas. Let discuss it lol
Old 06-16-2020, 08:43 PM
Default Re: Alternative to hydraulics In my dozer.
www.actuonix.com
This dozer uses dual 30mm stroke 50:1 L12-S actuators. Make sure to get the S series, as it takes an esc to operate, giving you infinite height adjustment.
The R series plugs directly into the rx and works exactly like a servo, as in if you put it on a stick ch, when the stick centers so does the actuator at mid travel.
https://youtu.be/5k-rGA7GCZU
Old 06-19-2020, 04:42 PM
Thanks, I was thinking of thoughs , I'll see what my money looks like
Old 06-25-2020, 11:15 AM
Finster's Avatar
Finster Finster is offline
Probably not the answer you were looking for but I'll put it out there just in case. How about doing an old-school cable dozer instead? No hydraulics needed. Only a winch which could even be a servo. Here's an example:
(Click the image to see full-size)
Hope this helps...
Old 06-25-2020, 05:20 PM
I've been thinking about these ...a really different build the dozer is kind of pricey to hack up...but..
https://www.3000toys.com/Spec-cast-C...-CASTCUST-1432
Old 06-25-2020, 06:16 PM
I know i'm weird and like old stuff, but those cable dozers look really cool!
Good thing i'm not in the market for a dozer right now, that one looks great jerry. (Do it.)
The cable reeving on that top one might get a little confusing, but with that much compounding a servo winch should have plenty of power to work with if the blade is heavy enough to not float.
Old 06-26-2020, 06:55 AM
Well my dozer is already built and hydraulic, I was just looking for something different, the hydraulics are becoming a pain .
Old 06-27-2020, 10:56 AM
carp carp is offline
have you thought of trying the actuators they sell on ali express for the huina excavators? servos already attached to lead screws https://uk.banggood.com/Huina-Plasti...iABEgI6jfD_BwE
if the servos aren't strong enough you can take them off and attach gearhead motors
