Old 03-10-2021, 12:47 AM
mbudz10 mbudz10 is offline
mbudz10 is on a distinguished road
Default Bruder CAT Excavator Hydraulic Conversion
Just about done with this conversion. I originally went with homemade actuators but did not have machine tools and things started to go south after a few uses. So I decided to grab a mini mill and mini lathe from harbor freight and teach myself about how hydraulics and machining. I used mostly brass for the rams except for aluminum (6061) pistons. The pump has a aluminum housing with steel gears and the valve is aluminum and brass as well. I built a 4 way valve at first but after a few conversations I decided to go with a 3 way and make it smaller along with the pump. I was able to make the pump and valve much smaller with the same output. For the model I used aluminum, brass and 3d printed parts (thank you NebraskTrever for the pivot files) to add support and make some pivot points much stronger. All in all I am satisfied with the results. I will try and post a video but if I cannot, I will comment with a link to a facebook page I posted on. Thanks for the look
https://imagizer.imageshack.com/img922/2958/fmlWnS.jpg
https://imagizer.imageshack.com/img923/5162/my2gtI.jpg
https://imagizer.imageshack.com/img923/4853/mKiRPS.jpg
https://imagizer.imageshack.com/img924/9236/95E441.jpg
https://imagizer.imageshack.com/img923/2792/fclY9h.jpg
https://imagizer.imageshack.com/img924/4695/DB3EdX.jpg
https://imagizer.imageshack.com/img922/5570/HSF3LW.jpg
https://imagizer.imageshack.com/img923/8892/zQLD9Z.jpg
https://imagizer.imageshack.com/img922/1272/Df4GEh.jpg
https://imagizer.imageshack.com/img924/7336/Bf1ntP.jpg
https://imagizer.imageshack.com/img924/5660/bWSMEG.jpg
https://imagizer.imageshack.com/img923/628/lnzPIU.jpg
https://imagizer.imageshack.com/img923/1748/59X9eo.jpg
https://imagizer.imageshack.com/img924/3889/jo0JwH.jpg
https://imagizer.imageshack.com/img924/4996/pyBCRg.jpg
https://imagizer.imageshack.com/img924/6299/dbEIpH.jpg
https://imagizer.imageshack.com/img922/2650/keoXdE.jpg
https://imagizer.imageshack.com/img924/3010/utSwpZ.jpg
https://imagizer.imageshack.com/img923/8260/5wlT3m.jpg
https://imagizer.imageshack.com/img924/5248/SwIsNh.jpg
https://imagizer.imageshack.com/img923/5682/K7OiXz.jpg
File Type: jpg rctruck1.jpg (157 Bytes, 75 views)
File Type: jpg rctruck2.jpg (157 Bytes, 75 views)
File Type: jpg rctruck3.jpg (157 Bytes, 76 views)
File Type: jpg rctruck4.jpg (157 Bytes, 77 views)
File Type: jpg rctruck5.jpg (157 Bytes, 76 views)
Old 03-10-2021, 12:58 AM
Default Re: Bruder CAT Excavator Hydraulic Conversion
Hopefully these are scaled down enough
File Type: jpg rctruck1.jpg (157 Bytes, 77 views)
File Type: jpg rctruck2.jpg (157 Bytes, 78 views)
File Type: jpg rctruck3.jpg (157 Bytes, 77 views)
File Type: jpg rctruck5.jpg (157 Bytes, 78 views)
Old 03-10-2021, 01:02 AM
More pics
File Type: jpg rctruck6.jpg (157 Bytes, 78 views)
File Type: jpg rctruck7.jpg (157 Bytes, 77 views)
File Type: jpg rctruck8.jpg (157 Bytes, 75 views)
File Type: jpg rctruck9.jpg (157 Bytes, 75 views)
File Type: jpg rctruck10.jpg (157 Bytes, 76 views)
Old 03-10-2021, 01:03 AM
2 more
File Type: jpg rctruck11.jpg (157 Bytes, 75 views)
File Type: jpg rctruck12.jpg (157 Bytes, 77 views)
Old 03-17-2021, 04:19 PM
mbudz10:
I'm seeing nothing. If you tried attaching images to your thread, this site does not allow that. I can't blame them, images burn up a lot of storage so by not keeping the image files on this site it costs less to maintain this site.
The first thread in the Construction Equipment forum is a Sticky telling how to link to your images.
Don
