Old 04-23-2021, 03:39 PM
cooker2003 cooker2003 is offline
cooker2003 is on a distinguished road
Default FlySky FS-I6X - Blend for Max Forward Speed
I would like to use one of the dials (VR-A) on the FS-I6X controller to act as a maximum forward speed limiter for my throttle channel. Tried to get this to work a bit but not all that familiar with this controller or how to setup mixes.
The way I'd like it to function is that when the VR-A dial is turned down, the max forward speed of the throttle channel would be 20%. If I turn the dial up to 100%, I would like the throttle channel maximum forward speed to then be 100%. Has anyone done this and can you give me some tips on setting up the Master/Slave relationships and positive/negative offsets?
Thanks!
Dave
Old 04-24-2021, 11:31 AM
Default Re: FlySky FS-I6X - Blend for Max Forward Speed
I don't know programming on the fs-i6x, but the original fs-i6 lets you set up a switch for Normal and Sport modes. So once that's enabled and set on a switch, in Normal you can set your throttle channel epa to like 20%, then throw that switch to Sport and have it at like 100% epa. I don't remember seeing anybody doing something like a live epa off a VR knob.
What are you trying to do with the master / slave channels?
http://runamok.tech/RunAmok/flysky_i6.html
Go down to Dual Rates
Elevon-mixing might work well for the master slave setting you were wanting?
