Old 07-27-2021, 11:09 AM
Default RC4WD JD Dozer Valve
Does anybody have pictures of the internals or how the rotary cams have to be positioned? I took mine apart to fix the leaking shafts with some new O rings.
Someone before me had it apart and drilled extra holes in the shafts confusing things.
I have the blade control valves oriented correctly but not 100% certain I have the other two valves for the ripper oriented properly.
I didn't realize the outer valves were different than the inner two when dismantling it.
