Electronics tech Anything to do with the electronics in a model. Lights, Radio, ESC, Servo, Basic electrical. |
Advice please don't want to spend loads, ESC which one do I need any wise words will help many thanks mike
We'll need a little more info to be able to really help you.
What are you planning on building? Any idea what All Up Weight you are shooting for? Those first 2 questions will help you determine what motor size and battery size you'll want to use. Once you've decided on a motor and voltage, then you can match the ESC to that. |
What ddmckee said....
give us a hint as to what your building.... |
Looking at their posts, possibly for:
1/16 50 ton excavator (4) 1/16 Bruder fire truck (4) Malaysian fast patrol boat (2) Large scale tractor trailer unit (1) What size motors does it use?
From 2018... and I thought I was a slow builder
It's for a Tamiya truck with poison motor useing 7.4 volt battery
I would guess a HobbyWing 1060 or 1080 would be plenty....if that's a brushed motor....not sure if it's brushless...
Posion Motor?
https://www.carson-modelsport.com/ca...906023-en.html Brushed 540 size can. Calling it a "puller" so i'm guessing 45 turn or higher? So any Brushed ESC rated for 540/550 motors is plenty for it
thanks
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
