Old 04-03-2011, 10:03 PM
TheMachinist's Avatar
Default Butler Bros Mark 5 logging truck
My father has begun the build on this piece of Vancouver Island history. I'll try to keep posting his progress.
The Tonka tires are just for mock up. He's using RC4WD tires when it's all done
Old 04-03-2011, 10:23 PM
firefighter-1177's Avatar
firefighter-1177 firefighter-1177 is offline
firefighter-1177 is on a distinguished road
Default Re: Butler Bros Mark 5 logging truck
WOW!!! This is going to be an awsome build!
Ken.s
Old 04-03-2011, 10:38 PM
steamer's Avatar
steamer steamer is offline
Jordy. Looks like he's off to a flying start. Looking forward to the build. Think he'll have it finished for the Sept. truck show.
Old 04-04-2011, 12:00 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Cool build Jordy.
What scale is he building ? Do you have any idea how many of those truck were in use ?
greg
Old 04-04-2011, 01:37 AM
The truck will be 1/12 scale and I think there were a few different versions of the truck but not many were produced. Steamer knows a fellow in Victoria who worked building them and has info on them.
Old 04-04-2011, 08:30 AM
This will be fun to watch. I like unique builds.
Old 04-17-2011, 08:27 PM
More progress: front axles are mounted and the rims are roughed in. Now the rear ends are starting to take shape.
The first pic is of my Dad's 1917 Southbend lathe he is useing to make all the parts with.
Old 04-19-2011, 07:16 PM
WOW that is a big truck! I like the front rims - excellent!
Old 04-19-2011, 10:28 PM
russisloud's Avatar
very nice lathe, i have a 1936 Southbend lathe same model
Old 04-20-2011, 12:10 AM
Yes they are a nice lathe. Where I work still has one from when it opened in the 1930's. Simple design and quite sturdy.
Old 04-20-2011, 11:37 AM
How large are those tires? I like the look of the fronts. Do you have a better picture of the front rims? I'd like to see what you've done to make it look like the bolts are all in them. I haven't really figured out how to do that for my Euc.
Thanks Reg
Old 04-20-2011, 01:10 PM
The front rims are GREAT looking! Tell your dad to keep up the GREAT work. The lathe looks a lot like my SB also. Does it have bearings in the headstock or split brass bushings? Mine has bushings with oil cups on all bushings. Can be a real pain to keep lubed and not make a royal mess!!
LYNN
Old 04-20-2011, 03:30 PM
the bolt patterns are just dimples with a center drill. Once the rims are painted they will look better.
The lathe is running in babbit bearings and makes a real mess when running for long periods.
I'll forward the kind words to him thanks.
Old 04-20-2011, 03:44 PM
Good to know, I think I will try that on my Euc. I'm going to have some Butler Bros Logging stickers made for the doors of my truck since they bought the real truck new and used it for road building. Hopefully sometime we can get these things together for a pic when their finished.
Reg
Old 05-02-2011, 11:04 AM
More progess
shaping the rearends and cab mock up to assess proportioning.
Also a pic of the schematic he's using
Old 05-03-2011, 11:48 PM
Jared Jared is offline
Originally Posted by TheMachinist View Post
Is this going to be like a real truck with axle shafts running from the diff through the axle tube to the outside of the hubs and the wheel bearings are outside the tube? Is it going to have planetaries? It's looking great!
Old 05-03-2011, 11:59 PM
No planetaries. Just full floating axles driving the outer hubs.
Old 05-06-2011, 01:23 PM
JensR JensR is offline
What a great design - and the model looks just as excellent
The front tires are RC4WD's Rockcrushers - the rear are MIL-SPEC ZXL ?
I think they do have some rather nice designs for our applications.
Old 05-06-2011, 07:30 PM
Yes they are milspecs. and they look very close to the originals. The only problem is the truck is going to weigh around 80 to 100lbs with a load on it and the tires are already flat with just the frame and axles on them. We need to add something inside the tires to stiffen them up.
Any ideas would be greatly appreciated.
Thanks for looking
Jordy
Old 05-06-2011, 07:41 PM
Crawler modellers use various foam inserts. I would assume that they are not typically as loaded as this truck, but it might just do the trick!
BTW, is this a Traxxas Diff?
Which model is it from?
