Old 05-07-2011, 12:43 AM
yoater yoater is offline
yoater is on a distinguished road
Default My daycab king
Im sure you've all seen it. but i'll post it anyways.
Retread on the left.
Ok who swapped out one of my rims?
and It doesnt get washed to much. constant silt & mud driving dispite being rwd. I removed the rear shocks the other day to do a mockup with some axial axles
I had started work on a custom sleeper for a globe liner or another king but this is as far as I ever got. I belive it scales out to 105-115"
Old 05-07-2011, 08:16 AM
Papabaer's Avatar
Papabaer Papabaer is offline
Papabaer is on a distinguished road
Default Re: My daycab king
Fantastic King Hauler and fantastic Pictures - at Pic 3 and 4 it looks like an Original in 1:1.
Everything which is round rolls well,
I´m round...
...so kepp on rolling, keep on trucking!!!
Greets from Germany
Martin
Old 05-07-2011, 08:43 AM
firefighter-1177's Avatar
firefighter-1177 firefighter-1177 is offline
firefighter-1177 is on a distinguished road
That king looks great! Are thoes stock king frame rails, or did you cut them down?
Ken.s
Old 05-08-2011, 12:05 AM
thanks. I cut the stock frame rails down by about 1-2" and used a peice of metal I had milled to fit inside the rail to re-attach the pieces.
Old 05-08-2011, 01:16 AM
love the look!! great build
Old 05-09-2011, 02:18 PM
Cool truck. Looks like her paint job is hiding a previous flame job? Almost like ghost flames.
Old 05-09-2011, 08:31 PM
your right about the flames. the original top coat on the flame job didnt stick to the first layer and when I pulled up the tape, some of the flames came up so I just sprayed it one color. at the moment I'm lowering the nose and changing the fenders because they've been the one thing that has bugged me about the king hauler.
anyone have some advice on lowering tandems or should i leave the rake?
with the front lowered the egg shape of the fenders becomes crystal clear.
or I could attempt to make a full set of low-profile tires. but it would still have a slight rake.
Old 05-09-2011, 10:19 PM
hippy's Avatar
hippy hippy is offline
hippy is on a distinguished road
low profiles! looks mean.
Shaun legaarden
Old 05-10-2011, 03:14 AM
heres a side on shot with all lowprofiles on one side. the stock bumper(minus plates) is about 1/2" off the ground.
Old 05-10-2011, 04:46 PM
Got some pics of my KH with the rearaxel mount flipped around,
http://rcmodeltruck.dk/forum/viewtop...hilit=largecar
let me know if you cant see the pics!
René
Old 05-10-2011, 04:50 PM
found a pic here nhttp://rcmodeltruck.dk/forum/download/file.php?id=8898&mode=view
René
Old 05-10-2011, 06:50 PM
hm, it makes sense that you might have to notch the frame. how strong was the frame after you did that?
lately every time I look at the king hauler I keep seeing it with a single rear axle with a set of lake pipes instead of the tandems.
edit: I was looking at your build and noticed you had mounted the leafspring oto the top screw. I put mine on the bottom and decided to see how low it would be if I mounted it on the top. at the moment all I have thats low-profile are the trailer super singles.
Old 06-22-2011, 11:03 PM
well I know its way to early for paint on the hood but *shrugs* its primer afterall Its going to be black with the stock decals. I'll get a set of pete fenders soon for it. I've been thinking of smoothing off the rib in the center of the hood but I', not to sure on it.
Old 06-23-2011, 12:11 AM
russisloud's Avatar
i like em smooth,
the hoods that is
Old 06-23-2011, 09:15 PM
because I like to stare at my projects instead of working on them
I'll fade the frame eventually. this is what I mentioned in the other post. however instead of full sidepipes they will exit between the steps and fuel tanks. except ofcourse super singles on the front and dual ss on the rear. although I'm torn betweein the single axle and tandem.
I had planned on making a full row of roof lights but I think I'll subtract 2.
Old 06-24-2011, 10:29 AM
sneaky-pete's Avatar
Master A-Modeler
I like the direction you are headed.......something different!
Troy
Old 07-07-2011, 11:16 PM
I finally did it.... now I've just got to get the single axle suspension for the rear. atm its just sitting on the springs. You probably will notice the lack of paint on the roof. I did some sanding so I could attempt to smooth the joint between the roof and the sunroof and where the old beacon was.
The cut is pretty rough atm but I'll fix it by the time I'm done.
Old 08-20-2011, 07:47 PM
I know this really isnt an update but I only recently got a new cordless drill
with rc4wds release of some lowpro tires I don't have to cut & reduce the tamiya ones
I think I might just paint the roof after filling in the holes and leave the rest of the paint as is.
theres going to be 6 red leds here. I'm going to fix the 2 larger holes. one was a switch and the other was a light that never worked. I think I need to redo the back panel as the drillbit decided to walk on me
Old 11-01-2011, 02:26 AM
Well I cant make up my mind. keep it a daycab or stretch it with the studio sleeper overall length is 28.5" I like it looking like this but imagine it painted with actual full size fuel tanks, steps, pipes, fenders and frame rails
Old 11-01-2011, 07:21 AM
Master A-Modeler
I always change my mind!
I mock up my builds in different ways to see what I like,and it never turns
out to be what I originally planed.
Troy
