Old 05-08-2011, 09:46 PM
enginemiester enginemiester is offline
enginemiester is on a distinguished road
Default MFU HELP!
I,m so frustrated, when ever I turn on my King Hauler with the MFU unit the horn always sounds before it "starts up" and it just started after swiching radios from a Spektrum DX6 to a DX7
I am out of ideas any help would be awsome!
Old 05-08-2011, 10:07 PM
rc_farmer's Avatar
Master Builder
Default Re: MFU HELP!
Give me a shout, maybe i can help ya
Giving up is not an option!!!
Old 05-09-2011, 06:35 PM
aseejr aseejr is offline
When using a Sektrum radio the AR6110 or AR6110E receivers. I know for a fact that the AR8000 and JR 9 channel receiver will work with the MFU with no issues. Having said this Spektrum have come out with a couple of new 6 channel receivers that I have not tried yet.
Albert
Old 05-09-2011, 07:52 PM
The original AR6100 will work or the AR6100B which is the replacement for the SR helicopter. The 7 and 8 Ch's will work as well. You can use 2 receivers to do it if you have an AR6000 and a BR6000 you can use the two together just put two functions on one and two on the other but it can't be two AR's or two BR's they have to be different and they have to be the same number series such as 6000 or 6110 however a 7ch is the same price as two six's so you would be better off buying the one and not having to mess with two. If 6Ch's are enough then look for or order the AR6100B it is cheaper than the 7 and it will work with the MFU the only issue I have found is that the horn doesn't always honk when you push the stick but other than that it work perfect.
Old 05-09-2011, 10:15 PM
Awsome I will have to try it out I know I have a few spare 6ch recivers, I'll have to check which model they are
